Question about Whirlpool LER5636P Electric Dryer
I HAVE CLOTHES DRYER MODEL NO. KEYW977BWHO AND WHEN I PUSH TH NO HEAT AND PUSH THE START B UTTON IT START AND THE HEATING ELEMENT STILL COME ON AND STARTS TO HEAT. DO YOU HAVE A SOLUTION TO THIS PROBLEM THANKS.
  • 311 Answers
There are a few possible issues you will need a quarter inch nut driver and and ohm meter to figure out the problem. First step remove the back panel. Once your back there to ohm anything out you have to remove one wire from the device your testing. You will have a skinny white thermal fuse with two wires going to it if that has no continuity its bad replace that (3392619) and the cycle therm next to it w/ 4 wires (3387134) and check your venting because the problem occured due to over heating. The next thing is you thermal fuse located at the top of the heater housing that comes in a kit with the hi limit thermostat which will probably requere some rewiring. The last thing to check would be your heating element which is a (279827) fairly expensive but easy to replace. Also before you replace anything make sure you are getting true 240v to the dryer.
Hope this helps _MJ_
Posted on Jan 31, 2010
My clothes dryer will not heat
This could be your Heating element, That is the most common thing to go out on a Dryer without a Make and model makes it harder to determine
Mar 26, 2016 | Dryers
Video test 3387134
This sounds to me like the heating element is bad. You need a meter to test it. You should not attempt this if you are not comfortable with it. Unplug it and remove the front of the machine, some have kickpanels under the door that come off with little effort after two screws are removed, Others require that the top of the machine be lifted off and then the front taken off. Then you need to locate the heating element. It is mounted to the bottom of the machine. You at this point should start cleaning the unit because it is most likely covered in lint. Then you can pull out the heating element box. NOTE where the wires are connected. Then you can check to see if the heating coil is bad. You can see if it is broken or you can use a meter to test it. There are also two switches on the unit that houses the heater coil. One is a thermal fuse and the other is a thermostat., Check those too.
Mar 24, 2014 | Dryers
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat not drying clothes
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
Apr 02, 2009 | Crosley Dryers
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
