Question about Dynasty DGRSC 60-6G Gas Kitchen Range
I own a Dynasty stove model DGR60-36-49 serial#130598F. The stove has stopped igniting, When turning on the stove all the lights (switch and thermostat dial) all come on but nothing happens with either burner. The elements do not heat up and the gas never turns on. All burners and the griddle on the cooking surface work fine. Can you help me troubleshoot this, direct me to who can, so I can order the parts to repair it? Thanks!!
  • 93 Answers
Here is the factory (Dynasty / Jade) ph # 800-884-5233
Posted on Mar 02, 2010
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
Ignition switch on dodge dynasty?
I had a similar problem years ago. As long as your dash lights come on, it's likely you can use an external pushbutton switch to run the starter. There are likely just 4 wires on the ignition switch. Power from the battery, and switched to:
accessories
main car stuff (dash lights, ignition, signals, etc)
starter.
splice in wires from battery and starter to new switch, and you're good to go. This worked for years on my old car.
Jun 01, 2015 | 1992 Dodge Dynasty
I need to know where the high and low limit switches are located on a Winrich Dynasty pellet stove
The Low Limit Switch, goes in the combustion fan housing. The High Limit Switch, goes in behind the Room Blower.
Here's a repair site for you to check out, in more depth. Hope this helps! http://www.butkus.org/whitfield_operate/whitfield-pellet-stove-low-limit.htm
Nov 21, 2014 | Pool & Spa
The Oven Won't Light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 08, 2010 | Dynasty DGRSC 30 Gas Kitchen Range
Need instruction book
Jade / Dynasty ph# 800-884-5233, most cases the big BANG noise is coming from the broken oven bottom pan, small BANG is normal, if you know how to remove the bottom them pull it out and inspect it, part of the V shape flame spreader may come off from bottom pan, you can have the welder weld it back on for you or order new bottom pan thru Dynasty. I'm not sure what do you mean by gas shut off. (turn off oven? turn off burners?)
Mar 22, 2009 | Dynasty DGRSC 36-4G Gas Kitchen Range
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Oct 23, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven Blows Igniters
sounds like you have a short somewhere. you may need an expert.
Feb 02, 2007 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
Sep 06, 2006 | Garland H283 Gas Kitchen Range
Dynasty DGRSC 60-6G Gas Kitchen Range Logo
203 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
