28p6515 philips widescreen tv when i turn it on screen says locked please can u help me
  • Anonymous Feb 20, 2008
    There's a little erd key in yhe lower left part of the screen.
    Sergeant:
  • 395 Answers
Remember that 0711 is the default AutoLock
code. If your access code has been changed by
someone other than you (a child, for example)
or you have forgotten the code, you can always
get in by inputting the default code.
Posted on Feb 19, 2008
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up.
After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 52" LCD TV
I think what you're talking about is the feature of the TV that auto-adjusts the screen for different pictures. What is does is tries to auto-fill the screen in case there are black bars on top (because of widescreen content) or on the side (regular tv content). It does it mistakenly if it notices too much black anywhere... happens a lot to me when credits are rolling. You can turn this off in your TV settings... I think you just set it to a specific type (widescreen, etc) instead of "auto".
Aug 21, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Jul 31, 2008 | Televison & Video
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
Lost remote and want to turn child lock off on a teac 76cm widescreen model no: EU3216STF
you will have to find out if you can acess the menu via any control on the tv itself,If this is not possible,then you will have to purchase a universal remote that will bring up your menu.
Feb 10, 2008 | Televison & Video
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
