Question about Philips DVP5990 DVD Player
It says no disk.. and disk is not spinng.. - Philips DVP5990 DVD Player
    President:
  • 173 Answers
If the disc is not spinning when you insert it in the player, then the problem is that the spindle motor has malfunctioned. The spindle motor is the device that spins your disc so the player can read the disc.
In the picture above you can see the optical reader lens (small glass bubble looking component) and the top of the spindle which the disc sits on (large circular component) and the motor is located directly below that.
The good news is that the spindle motor's average cost is between $25-40 dollars. The bad news is that if you can fix the problem yourself, you will need to remove the entire optical laser assembly in order to replace the motor its self and is a pain. You can have a service technician fix it for you, but the cost will now average you $80-100 dollars depending on what service charges are in the area you live.
I would suggest that you remove the cover and visually confirm that the disc is not spinning, just to make sure. You can try buying a can of compressed air and cleaning the inside out really well first because there could be dust build up which could prevent the spindle from spinning properly.
If you see that it is spinning up, then you may just need to clean the discs or the optical lens. You can take a look at my tips and tricks in my profile for instructions on how to clean the optical reader lens. I wish you the best of luck in fixing the problem.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Posted on Jan 31, 2010
When I insert a disc I get a "Disc Error" after
Most DVD players display that kind of error when unable to read data on you disc media. Try other DVD disc if that post the same problem. A new one will test if it is the unit problem or the media disc problem. If it post the same problem on a disc that runs well on other players then your player probably has a dirty lens. You can clean the lens using commercially available DVD lens cleaner on the market.
Jun 14, 2011 | LG DP450 Portable DVDDivX Player
The squeaking noise is when the washer is spinng like a squeaky belt
no belts in a washer just a tramsmision it could be going out
Dec 13, 2009 | Maytag MAV3855A Top Load Washer
Freezer compartment working fine but refridgerator compartment not cooling . DFF8803W
with most fridges that have this problem.there is a problem with the evaporator motor not spinng this needs to be checked for proper air circulation.
Sep 17, 2009 | Danby DFF8803W 8.8 Cu Ft Frost Free...
Fills up then buzzes not washing or spinng just a buzz also blows the breaker
Sounds like motor burnt up. Search online for replacement.
Jul 10, 2009 | Maytag LAT2301AAE
Need to lookat manual for a Penn 7000
What problem solution required please mention.
Jun 01, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Xbox360
it wont play games because it dose not have much mb power
Feb 17, 2008 | Microsoft Xbox 360 Console
Grinding noise
replace your drive coupler. cheap fix. i charge around $60.00
Jan 01, 2008 | Kenmore 22422 Top Load Washer
DVD ROM
Have you tried using a lense cleaner disk?
Can you hear the disk spinning at all?
Is the problem with both cd and dvds?
What kid of disk are you trying to play? Some dvd roms will not read dvdrw disks.
Dec 28, 2007 | Dell Inspiron 2200 PC Notebook
Philips DVP5990 DVD Player Logo
888 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
