Question about Vacuums
The vacuum belt keeps on breaking. - Vacuums
  • tanoose1203 Jan 31, 2010
    Thank you! The info was very helpful.
  • 10,515 Answers
Most likely if your belts keep heating up and breaking there is a problem with the brush roll ( http://www.totalvac.com/store/graphics/00000001/EB29027.jpg)
The roll may be worn down where the belt is supposed to fall, causing friction between the brush roller and the belt. Brush rollers can get quite pricey, so your best option would be to bring it to a local vacuum shop. The price you will pay to have them look at it will definitely be less than purchasing a new roller. In most cases, with newer vacuums, there will be a simple issue that the technician will be able to quickly fix. It could be something as simple as the roller is not positioned properly.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 31, 2010
Belt keeps breaking after only short use on vacum cleaner
Each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn. The belt must be installed according to manufacturer directions for best performance, or the belt will chafe against the interior housing parts and break prematurely.Sharp debris, a low height adjustment setting or vacuuming up rug corners may cause the rubber belt to snap or wear prematurely. Check the height adjustment for the vacuum, and use a higher setting for plush rugs. Avoid vacuuming sharp objects and corners of the rug.
Jul 27, 2011 | Vacuums
Why do the belts keep breaking
Well the problem happens due to the belt If the belt not installed correctly, the rubber belt will grate against one of the components in the roller brush housing. The friction of the belt against the housing produces a pungent burning odor. To correct this you need a right belt, each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn.
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Bissell 3576 CleanView II Bagless Upright...
The belts keep busting. i check the roller brush and it moves easily with out the belt. why do the belts keep busting?
1) could be the belts you are using are not for that particular model.
2) depending on what you are vacuuming, a rug on the floor for example with tassels will always break the belt when it gets caught into the roller brush.
Nov 04, 2010 | Dirt Devil Featherlite Bagless Vacuum...
My kenmore vacuum keeps breaking belts
Breaking belts is usually caused by the motor keeps going and the roller gets stalled or locks up. make sure you can spin the roller freely by hand befor replacing the belt
Oct 15, 2009 | Vacuums
My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Jul 03, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Why does the belt keep breaking as soon as I turn on the vacuum?
Hi Have you got the correct belt? If its breaking then the brush end caps or something is clogged. If you can get into the floor head ensure you look at the actual brush roll to see if there is anything is clogged or trapped. Remove all matter of dust and see if that works.
Mar 23, 2009 | Eureka 431A Optima Bagless Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Generic problem for all Vacuums
Posted by andy78billy on Apr 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
The rubber band that turns the roller on the vacuum keeps breaking. I just bought a new rubber band, put it on, and it broke immediately. Can it be fixed?
I see there could be 2 problems – either your revolving brush has hair or thread buildup in the ends of the brushroll of which is causing the belt to break and would need to be cleaned out, or check the bearings on each end – they could be **** as well, or the motor shaft or motor assm is not tuning freely and in that case the motor should be replaced and it is not the belt – one other thing is to make sure the motor is in there securely. Once you get the belt on then roll the pulley and the belt together to make sure the belt is on correctly if the brushroll spins freely.
Apr 18, 2008 | Vacuums
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
