Question about Panasonic PT-56HX41 56" Rear Projection Television
No picture or sound on Toshiba 53HX71 Rear Projection TV
The red color was out of wack, so I replaced the convergence IC's. I put everything back together and plugged it in. All I get is a click on the main power board. The power light on the front of the TV is on and is solid, but no picture or sound.
    Master:
  • Panasonic Master
  • 996 Answers
Faulty tuner if circuit, try on audio vedio connectors
Posted on Dec 23, 2014
Gm pagbigyan mo naman ako nga pokemon
Posted on Jan 31, 2010
Convergence issue Blue not convering correctly, but the other colors do. The blue is warped at the top and bottom of the screen. Is this problem something that can be fixed?
Yes,the covergence ICs and precision resistors can be replaced to rebuild the area. A reputable shop may charge around $300 . If you are technical person,I can guide you further to do yourself!
Jun 04, 2010 | Toshiba 53HX71 53" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
I have a Toshiba projection tv 53HX71 and I get 2 or 3 red shadows on everything, how do I fix it
The convergence IC's need to be replaced (possiply 2 fuses will also have blown) this is a common problem.
Sep 18, 2009 | Toshiba 53H71 53 in. Rear Projection...
check for solder bridging between the IC pins. also make sure the wire connections are back in the proper locations
Feb 14, 2008 | Toshiba 50HX70 50" Rear Projection...
Help
your having convergence circuit problems, you`ll need to change the convergence IC`s and any burnt resistors in the convergence circuit, if you have questions e-mail me back, good luck, BMW Rider
Jan 03, 2008 | Toshiba 53HX71 53" Rear Projection...
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Convergence problem
sounds like bad solder connections on convergance ic solder then if the problem still there replac ic
Oct 24, 2006 | Toshiba 57HX81 57" Rear Projection...
Panasonic PT-56HX41 56" Rear Projection Television Logo
169 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
