Question about Dehumidifiers
How much water to put in the water entering tray
How much water can I put in the tray the water enter tray,
  • 111 Answers
Dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Posted on Jan 31, 2010
How do I empty the water tray on a maytag dehumidifier
Put machine on pause, On the front of your machine you'll see a seam that is the separation of the tank, gently put your hands on the side of the machine and you'll see and feel indentations of where you have to gently pull forward until you feel the tank coming off, make sure when you pull it is with equal pressure and you can use your thumbs to hold the machine from rolling when you take the tank off. ( it is a two handed operation), get ready for the tank coming out because depending on the amount of water in it, it may be heavy.
If your still stumped, I guess I can video it being done?? Good luck and let me know how it goes!
Jun 20, 2014 | Maytag M7DH45B2A Dehumidifier
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
New unit, try using in basement. nothing happen, should humidity settings be high or low? Dose humidity level be high? In the bucket whats the plastic cup about? do something alow water to enter bucket?
If you trying to remove humidity, the setting or percentage of humidity to you want to remove should be set low. it's actually the humidity that will be left in the air. In the Hot Summer months, you want lower humidity, as opposed to the Winter months, when you want higher humidity.
"Plastic cup inside the bucket" - that's got me stumped. But, I suspect, it may be a float valve to turn the unit off, once the bucket reaches the full level. The water enters the bucket through a drain tube or hole from inside the dehumidifier, above the bucket.
By best advice, since this is a new unit, that you recently purchased, is read the Owners Manual/User Guide and become thoroughly familiar with the proper operation of your Dehumidifier, as well as how to properly maintain it. As, they aren't maintenance free.
Apr 15, 2011 | Haier DE65EJ Dehumidifier
Bought a Maytag 65 pint dehumidifier second hand. A hose or tray didn't come with it. Need to buy parts and would like to get a free owners manual. Model # M7DH65B2A*A Thank you, J Duke
You can find the manual and the parts online a Sears Parts Direct. However, when you enter the model number, drop the *A off the number.
FYI - This unit was made for Maytag by Fedders. And they make one of their own, with the same model number.
Hope this helps you.
Apr 01, 2011 | Maytag M3DH30B2A Dehumidifier
It collects some water but it also spits water out
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
Nov 12, 2009 | Frigidaire FDL50R1 Dehumidifier
Our humidifer runs but does not collect water.
Againg, if theres no moister in the air it wont remove water. if you feel the location for exmaple a basment feels cool when entering , then mosuet exist. dehumidifer will make any location warm when removing the coolnest in the air. within summer hot months it will collect more water than in the winter months. if it does feel cool and machine dont remove the water. call a repair person.
Oct 04, 2009 | Fedders R6DH45X Dehumidifier
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
Fdk45p1 dehumidifier
Has anyone figured out how to get a 25-pint Frigidaire dehumidifier (model FDD25S1) to put water out the drain hose for continuous draining instead of into the bucket? It appears to be impossible to connect the hose in a way to avoid water leaking into the bucket.
Jun 06, 2008 | Frigidaire FDL45P1 Dehumidifier
Dehumidifier runs but does not extract water
dehumidifier runs well, however will not drain any water
May 28, 2007 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
112 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
