I have indesit cooker hood which i was using with light + fan in operation. All of a suuden whole thing stopped working , fuse/plug all ok - is there a fuse inside cooker hood that i cant see???
Comments:
Feb 18, 2008
- have already checked the power form the wall - all fine!!
-   how can I find the how the power goes into the cooker hood?-   deesoufi
May 04, 2009
-   The lights and fan are intermitting. Thought a fuse was blown, and checked it out but everything was fine. A few days later it was working again. Never now when it will work.-   Guest
Dec 12, 2008
-   My light works but hte fan does not? Same problem, are there fuses??? -   Guest
Nov 13, 2008
-   Same problem.
Bulb and fan stop working. Power supply OK.
Did anyone find another fuse, or a wiring problem inside the hood?
-   I have the same problem. The fan and lights all worked perfectly, then all quit working. Just as if the power had being shut off. The breaker switch is on. Please help.
-   mervbrandt
Hang in. Somewhere in the hood is a disctribution point for the wires going to the fan and light. Some hoods have a joint there. If there is a break, a loose wire or a fuse it will be there. Let's look, ok.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 29, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the power is coming through. the ball bearing spins for a few seconds and then stop what could be the problem
I HAVE THE SAME PROBLEM WITH A ALLURE 2 JUST STOPED WORKING ?
BUT POWER IS COMING IN THE UNIT ALL SEEMS OK, CHANGED THE LITTLE GLASS FUSE ON THE CONTROL UNIT.STILL NOT WORKING .CHANGED THE CONTROL UNIT ITSELF STILL NOT WORKING
HELP !!!
I am looking for a new plastic switch set for a Faber hood extractor model number INCA HC HILO 72....
(More)
I am looking for a new plastic switch set for a Faber hood extractor model number INCA HC HILO 72. Any ideas .... Thanks -Andy
Where is a good place to purchase replacement bulbs for my Tecnowind vent? It looks like the base is...
(More)
Where is a good place to purchase replacement bulbs for my Tecnowind vent? It looks like the base is a Europeon style and the bulb is 110v 40w. Thanks, Bob
What is an allowable distance between the range hood elbow to horizontal and the external blower...
(More)
What is an allowable distance between the range hood elbow to horizontal and the external blower affixed to an exterior wall. I am looking to install A Broan Elite RM 60000 Series using 900 cfm external blower 332H. Thanks.
