Question about Acer AL1916W 19" LCD Monitor
Wavy display issue ... please assist!
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Thanks in advance!
Nick
  • chriscurtis1 Mar 07, 2009
    i have an AL1916W acer monitor and mine too is wavy. Just woke up one morning and it was like that. thought maybe was drivers but nothing seems to work.
  • Anonymous Apr 01, 2009
    wavy lines of brightness across the screen horiz. flowing down the screen vert. (just showed up one day). Changed refresh rate just changed the waves speed, didn' clear it.
    Problem Solver:
  • 15 Answers
Well i know what exactly the problem.But that is a professional technician work.there are two capacitors located inside of monitor on the power board need to be changed.220mf/25v both are the same value of farad and voltage. replace with the same "mf&volt" please.ERIC
Posted on Apr 11, 2009
What ? You copied the same thing I asked ... ? Douchebag!
Posted on Feb 22, 2008
    Scholar:
  • 198 Answers
Posted on Feb 20, 2008
Computer not recognizing HDMI, but recognizes VGA
i would try go to - graphic properties(options) and try to browse for display options, if nothing's there than browse for update for your graphic card drivers on laptop producer website or hdmi drivers
Feb 11, 2014 | HP Computers & Internet
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
By default the display should show on the external VGA monitor.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&products_id=560
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Regards,
joecoolvette
Jan 15, 2012 | HP Pavilion dv6000z Notebook
Using notebook display and external monitor: HP Pavilion zd8205us primary display is garbled, secondary display is clear and good, It doesn't matter which display device you set as primary or secondary
try to switch the blue VGA cable that is connected from the laptop to the external monitor. You may also restart your laptop and set aside the external monitor to check if the laptop is still experiencing garbled display... If it still is, then it is a monitor issue and need to address to HP personnel by calling HP hotline. Otherwise your issue will be resolved by simply doing that..
Nov 14, 2010 | HP Pavilion zd8000 Notebook
Display on HP DV6000 is scrambled.
Reseat the LCD cable on the laptop end and also behind the LCD panel. Since it working on external monitor the graphic card is working fine.
Oct 14, 2009 | HP Pavilion dv6000z Notebook
Your problem is the screen itself, sounds like your graphics chip is fine by being able to use an external monitor. Change out the display, but also check the flat data cable on the back of the screen and make sure it just didn't slip out of the socket.
External monitor
This does not appear to be a display issue but more of a failure of explorer to load. Try pressing Ctrl + Alt + Del so it brings up task manager. Click file then go to new task and type Explorer and see if all of your icons and such show up. If they do you will want to install a spyware remover such as spybot search and destroy from safer-networking to check for any spyware that is preventing explorer from running. Also check your event viewer in safe mode and see if there are any errors when you boot.
Dec 19, 2008 | HP Pavilion dv6000z Notebook
Shadows and Ghosts on the Screen
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Acer al1916W Driver updates
Feb 17, 2008 | Acer AL1916W 19" LCD Monitor
Moniter color callibration
Feb 17, 2008 | Gateway FPD2275W LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
287 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
