Question about Philips Televison & Video
Cant program channels philips pl 4125 c101
Cant program channels philips pl 4125 c101 trying to hook to cable and it will not program in all the channels. can't even get a menue screen to come up to adjust color or anything.
4 Suggested Answers
renx
  • 71 Answers
SOURCE: Where are jacks to hook up dvd
Hi, I downloaded the manual for this TV to make sure of its connectivity. The only connection the TV has is a coaxial connection for ant/cable which will accommodate cable, antenna, VCR, DTV. It does not accommodate sources without coaxial outputs such as most DVD players. However, there is a solution. Radio Shack, Best Buy, WalMart etc, all carry a device called an RF modulator that will convert the A/V outs from the DVD to coaxial. Here are a few links below of the device you will need to get you up and running.
http://www.radioshack.com/product/index.jsp?productId=2103095
http://www.walmart.com/catalog/product.do?product_id=9893723
http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&st=rf+modulator&lp=2&type=product&cp=1&id=1067388827858
Posted on May 05, 2009
SOURCE: Philips 27S300 C101 TV. How do I program the
use this user manual because you will continue to get some problems with your TV. print this use manual;
http://www.p4c.philips.com/files/2/27pt643r/27pt643r_dfu_aen.pdf
Posted on Sep 16, 2009
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
How can we get the normal channels on our Philips under the counter TV, 7"?
If the tv doesn't have a digital tuner you have to hook it up to cable or use a digital converter box and set the tv to channel 3 in order to get a program. If the set does have a digital tuner hook it to cable or antenna and auto search for channels.Good luck, Russmann.
Jan 03, 2011 | Philips Televison & Video
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
No remote tv stuck in cable mode no channel 3
See if you can get a manual for the set at web site or try a google search.
Sep 07, 2017 | Televison & Video
I don't know how to set the tv to receive all of the channels
Enter the "menu" and select auto program. This will allow the set to search for all available channels. There is also a possibility that when you hooked it up the little wire center conductor in the cable might have been bent over when you hooked it up. Check that first.
Apr 16, 2010 | Sharp 19R-M100 19" TV
Feb 17, 2010 | Philips Televison & Video
I have a Philips TV, model HD2717 C101. All channels do not display--Why? It skips quite a few channels on scan, the only to get them is to actually select the channel individually.
Hi are you running it off of an antenna or cable?
Assuming you have a digital tuner and are selecting the proper type of channel search Ie: cable or air it could be that the tv needs a firmware update to the tuner.
I have experienced similar issues with several TV's I had an Olevia 37" HDTV that required a firmware update to get the tuner to properly decode channels.
I also have seen lots of cases were people have cable hooked up without a cable box and receive "mixed" channels.
I currently have Comcast and have 6 TV's hooked up 3 with cable boxes and 3 directly off the line. According to Comcast I should not be getting anything besides "basic" channels without a box but using the digital tuner in the TV's does pickup most of the channels and even some HD channels that are not there using their boxes.
Interestingly enough none of the TV's tuners decode the channels into the same "channel." As an example HGTV on 1 TV shows up as 84.4 but then 86.1 on the second and something like 84.11 on the third.
My recommendation run the auto program again then go through channel by channel and see if anything needs to be manually entered or deleted. I know this is a pain in the **** and takes about 20 minutes per TV but hopefully that will tell you if your TV tuner is relocating the channels to another channel.
Lastly if your tuner is not digital or if the tuner can't be updated you may have to use a secondary tuner such as one in a VCR to get the channels you desire.
This whole Digital Conversion that we have undergone has brought to light for me at least that our government and corporations don't care about the real world impact on the ordinary person.
Sure they made money on reallocating bandwidth and sure tons of new HDTV's and digital products (including digital cable) have been sold but I haven't come across anyone who feels they have benefited from the conversion forced upon us.
Hope this helps sorry about my rant.
Dec 28, 2009 | Philips Televison & Video
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
Philips 27S300 C101 TV. How do I program the channels into the Philips TV. It's hooked up directly to cable. Right now I need to type in the channel I want to view. The channel up and down button skips...
Sep 15, 2009 | Televison & Video
MORE channels! for CHANNEL SET UP PHILLIPS pl9127 c101/ 27f 800 7583
I need more channels. I ONLY get 13 channels, 1-13. I know im supposed to have more... Phillips Consumer electronis: manufacture no# 3210t127a
Oct 28, 2008 | Philips TS2746C TV
I need to program my tv is cable ready
plse help, i have a cable ready tv hooked up to the coax out of the wall directly to tv and only get 1-13 channels??????
Sep 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
218 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
