Question about Goodman Heating & Cooling
GMN FLASHES 4 TIMES
GMN060-3 LED FLASHES 4 TIMES
I'VE TRIED RESETING POWER & CHECKE FILTER.
  • 306 Answers
The four flashes means limit switch is open or there was a flame roll out. Is the unit very old? If not make sure all vents in house are open and not blocked to let the heat move out of the ducts. Maybe one limit switch is getting weak. They don't go out very often but trying to eliminate problems to narrow it down. ken
Posted on Jan 31, 2010
Panasonic TC P5G20 turns on but screen will not activate. It then clicks and the led blinks 13 times. I've turned it off and on a few times and once the light blinked 4 times, but it's now...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 16, 2014 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
HP Designjet 500 has a locked screen. I have been trying to get the plotter to run on our new computer and it locked up after installing the current Firmware and driver updates. Any suggestions would be...
Dear Friend, It's a serious issue what I understood & confusion is control panel locking facility not avail in this model, how its locked?.. Simple method to catch the faulty part through power LED behaving s..(Power led located on power button)
# LED is OFF - This indicates that the Power Supply Unit is
completely dead. Try the following:
1 Check that power cord is connected correctly to the Printer and to the Power Socket.
2 Replace the Power Supply Unit
# LED is ON (all the time) - This indicates that the Main PCA is completely dead. Replace the Electronics Module
# LED is Flashing - A problem has been detected with the previous firmware upgrade. Try re-send the firmware upgrade file.
# LED Flashes twice every few seconds - The Printer cannot detect the Interconnect Cable. Try the following:
1 Check that the Interconnect Cable is connected correctly to the inter connector PCB & Electronic module.
2 If the Interconnect cable is connected correctly and the LED continues to flash twice then replace the Interconnect Cable
LED Flashes 3 times every few seconds - The Printer cannot
detect the Front Panel. Try the following:
1 Check that the Front Panel is connected correctly to the Interconnect PCA.
2 If the Front Panel is connected correctly and the LED continues to flash 3 times then replace the Front Panel
LED Flashes 4 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module
LED Flashes 5 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module.
Now U decide that whether firmware uploaded properly or not?..if not its sure that Electronic module gone.. you have 2 replace it..
Any further help/query pl reply, best of luck..
Oct 02, 2013 | HP DesignJet Office Equipment & Supplies
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
When i turn on the tv the led flashes 4 times and tv takes 4 minutes to come on and when it comes on the led flashes 5 times
Flashes of your led light indicates an error code. This is usually caused by leaky filter electrolytic capacitor. This will affect the regulation of the supply and sometimes needs a little warm-up to function normally. This faulty capacitor is in the regulator section/low voltage power supply. The symptom will get worst if not isolated.
This is not DIY. I've advice you to send it to repair shop or look for a qualified technician to fix the problem.
Hope it may help you!
Have a nice day.
JDVillanueva
Jan 31, 2011 | Televison & Video
We can't turn on the TV. We[ve tried the remote & manual controls & have unplugged it & plugged it back in using both the surge protector and wall outlets to no avail... Any suggestions?
The power LED indication light flashes or totally dead?The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Oct 17, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Heating & Cooling Logo
79 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
