I have the same problem. My computer is barely one year old and every so often I have to do a forced shutdown. I run regular sweeps and scans and always get a clean bill of health.I have the same problem. My computer is barely one year old and every so often I have to do a forced shutdown. I run regular sweeps and scans and always get a clean bill of health.
You can't post conmments that contain an email address.
Hi, pls. check whether you any license anti virus on you laptop. if yes then pls. check it is updated or not, if not pls. update it and scan your all system for viruses.
also you have to check that any other services are running in backgroud.
HAVE A LOOK AT THE FAN IN YOUR LAP TOP MY DAUGHTER KEPT DOING THE SAME SO I TOOK IT TO THE GARAGE AND BLASTED IT WITHAIR TO CLEAN ALL THE DUST THAT HAD BIULT UP OUT TRY IT ...
It is the battery. It is damaged, and because of that it changes the voltage of the AC. the best solution is to replace it with a new one, but until then, work without it, or you might have fried lap top
hi..the solution is u need to re-format your system and Hard Drive and re-install a new OS..i think your system is a lot of Bugs/error came from virus or worms...but b4 format back-up your files using like,USB flash drive or external Hard Disk/Drive..Good Luck mam/sir...God Day and God Bless..^_^
I would suggest you just plug it in and do not power on the laptop for a few hours. Then try. If it persists reboot into safe mode and disable hibernation then reboot
You should go to the BIOS and load the default settings. Also, check your device manager to check if all hardware is installed and functioning properly (no conflicts, etc).
This can be solved...do a live chat...any expert can solv your problem...
Need More to Know?..then please reply ____________________________________________________ Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
