Question about Acer Aspire 3004WLCi Notebook
My acer 3004wlci wont power up. when i put the fully charged battery in the yellow lights flash for 3 seconds but wont turn on & when i use the elec cord it does nothing at all.
I had the same problem. I removed the battery and just used the AC Power Adaptor. The machine powered up and ran fine. I replaced the battery and have had no problems since (2 years ago now)
Posted on Mar 30, 2010
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I cant open
Push the power switch up as far as it will go and see if the blue ring on the front of the player lights up.
The Fuze's power button is not a traditional button but a slider, so if you did not push the slider up all the way, this may be the only reason it was not powering on.
Reset the Fuze by pushing up on the power switch and holding it in the up position for 10 seconds.
Try to power on the Fuze again after it has fully rebooted.
Connect the Fuze's USB cord from the Fuze to a USB port on your computer.
You should see a yellow charging light illuminate and the battery symbol blinking on the Fuze's main display.
Once the battery stops flashing, the Fuze is fully charged and you can try to power it on again.
hope this helps
Sep 27, 2012 | SanDisk Sansa Fuze MP3 Player
It wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Jan 05, 2010 | Sony Ericsson K850i Mobile Phone
My ps3 wont fully turn on/ flashes for a second, then goes right back to red. essentially shutting down. it wont eject disk either.
this is known as the yellow light of death or ylod..sony charges $150 to fix...if you have any knowledge of electronics...you can find a fix on youtube...just google ylod solutions or yellow light of death solutions..sorry..i had the same problem twice..luckily i paid 75$ for the lifetime warranty at toys r us........
Nov 07, 2009 | Sony Playstation 3 (PS3) Console
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Wont turn on
pull the battery and try to power on. if no good test the power adapter with a meter - should give 18-19 volts. if it boots with battery off, power up and put battery back on to charge.
hope this helps
Jan 17, 2009 | Acer TravelMate 6460 (LX.TED0Z.071) PC...
Power Supply Plugged In And Battery Fully Charged No Power
has it gone into hibernation? ... try holding the power button down for 10 seconds
Sep 23, 2008 | Toshiba Satellite 1415-S173 Notebook
Acer Aspire 3004WLCi Notebook Logo
361 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
