Question about Gateway 838GM (RB838GM) PC Desktop
Custimization tips for Gateway 838GM
I'm looking for a way to customize my Gateway 838GM to its full potential. Any suggestion?
  • Samuel Zirene Jan 31, 2010
    I just want it to work as good as it can in efficiency. Speed, Boot Time, Hardware Changes, Upgrades, and Gaming basically.
  • Davis M May 11, 2010
    Well, um, customize it to its full potential of what...? Visual Prettiness? Speed & Boot Time? Video/Audio Editing? 3D CAD work? Gaming? ---- Hardware Changes & Upgrades? Software Tweaking? Budget or something? ---- Specifics would certainly help. Please post back with something more specific about what you're wanting to accomplish and 'where'.
System Setup
Well we need to know if it's windows 7 or 8... first. and the brand...
Apr 23, 2014 | Gateway 838GM (RB838GM) PC Desktop
I want to run a Dban disk, but nothing I select from the BIOS menu actually boots the computer from the DVD drive containing the disk. I have an ancient Gateway 838GM with Windows xp
Make sure the first option in BIOS boot options is the CD\DVD drive. If it is not you need to move it to the top of the list (usually the +- keys).
If it is already at the top of the list then the problem is that the disk inserted is not formatted correctly to be booted from. If no CD\DVD drive shows up in the BIOS then the drive is not able to be booted from period
Nov 21, 2013 | Gateway 838GM (RB838GM) PC Desktop
My PC froze while it was on, when the Recovery System was attempted, it says its needs a user partition, that it needs a OS, and that files are corrupted
Try reinstalling the drivers first--you can grab the drivers off the Dell website in their support section with full instructions.
Sep 13, 2010 | Gateway 838GM (RB838GM) PC Desktop
Gateway 838GM Video Card?
Hi i'm Rain.
Ok lets put it this way. You get what you pay for. If you want quality video you have to be willing to pay the asking price. Yes you can find it cheaper ,..But look at the word cheaper.
Yes the Express x16 HDCP will work with your system .
If i had to solve the issue i would have said get the PCIE.
All you are looking for is a video card with high speed .
I hope i have been helpful in this problem.
Jan 28, 2010 | Gateway 838GM (RB838GM) PC Desktop
Gateway 838GM will not turn on even after installing new power supply. It was on and began making a loud noise and just quit.
Did you test the old power supply? If not, noise could have come from CPU fan. In either case, problem is most likely main board and/or CPU. Try removing all plugin components except CPU and heat sink and see if you get any signs of life.
Aug 03, 2009 | Gateway 838GM (RB838GM) PC Desktop
I need to know the size cpu fan for gateway 838gm. Can't find anywhere on the internet
You have a 3GHz intel processor socket #775.
here is a great place to purchase: Also this page (link below) contains several products - see what you think
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=50002177%2040000574%201371026035&name=LGA775&SpeTabStoreType=0&ActiveSearchResult=True
Hope this helps, please leave rating
May 07, 2009 | Gateway 838GM (RB838GM) PC Desktop
Gateway 838gm has no video output. no beep during power up how do I trouble shoot
If you are getting nothing, no beeps, nothing spinning then you might have a bad power supply or failed motherboard. I would also take this time to inspect the motherboard (mobo for short). It should not have any capacitors (they look like tiny soda cans) that are bulging at the top, swollen at the top or leaking any kind of fluid. They should be perfectly flat. If your motherboard looks good then I would get a new power supply. You will want to take out your other power supply and look for the output watts. It will probably be in the range of 150 to 300. You must buy a power supply that has more than what you take out, never less. If you have put in a bigger video card or have a lot of expansion cards that you have added to the system you will want to increase the power supply over 400 watts.
Mar 22, 2009 | Gateway 838GM (RB838GM) PC Desktop
Gateway 838gm no video
Are any fans running? If not take the power supply to a reputable computer repair person. They can test it while you wait. If the power supply is good or the fans are working then I would remove that new RAM. My guess is the power supply is bad.
Good luck
Computers & Internet Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
