Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Error E1 Just moved to a house where a Fisher & Paykel EZKleen Stainless Steel DD605SS - 2 drawer is installed. Tried to get it going and both drawers show a plate icon and 38 and 45 mins respectively, then there are some sounds and we get Error E1 on both of them. There was no manual and the video they left didn't help. Any ideas? I would also be interested in a link to a User's guid. Thank you, Julia.
  • 41 Answers
There is no e 1 error in dd603 , maybe u1 or f1 , u can call 1800650590 nd ask hem to send the use nd care manual , or download it from fnd p website ,
If it is U1 its saying taps not turned on , more than likey u have a F1 fault which is a flood sensor error , which means u need a new mains filter board around $50 to buy
Posted on Jan 31, 2010
What brand of detergent should i use
I have had good luck with the powdered dishwasher detergent from Wall Mart's brand Great Value.
Before I switched to this brand I had to clean the washer drawer several times because the detergent I was using was not dissolving properly and would leave a residue in the bottom of the drawer and on the dishes.
Aug 23, 2013 | Fisher and Paykel DD605SS Stainless Steel...
How much is service and maintenance of Fisher Paykel bottom draw that does not work
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Jan 03, 2013 | Fisher and Paykel DD605SS Stainless Steel...
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
Oct 18, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Machine displaying f1
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Mar 14, 2011 | Fisher and Paykel DD605SS Stainless Steel...
Drawer wont drain and motor noisey
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 19, 2011 | Fisher and Paykel DD605SS Stainless Steel...
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Water does not empty from the draws DD605SS
The pump may have something lodged in the impeller and will not allow it to pump. To access the pump, the drawer must be removed and turned 90 degrees to the left. Unplug the wire harness to the pump. Loosen the clamp on the drain hose and then remove 3 screws holding the pump. I've found rubber bands wrapped around the impeller.
May 16, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
662 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
