Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
How do i make sure it is on - Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
  • 438 Answers
Is your water getting hot,,, NO has your barker tripped, do you want to tackle this repair, do you have the tools, and a multimeter ? if so get back to me
Posted on Jan 31, 2010
My whirlpool 50 gal natural gas water heater wont stay lit?
Are you sure the pilot is heating up the thermocouple? Make sure the flame is close enough to the thermocouple. Also make sure the thermocouple is seated properly in control valve. Try unscrewing and resetting it back into place.
Feb 10, 2013 | Whirlpool Water Heaters
Keeps blowing circuit breaker
The most likely malfunction is that one or both of the heating elements have shorted out. The elements are not that hard to replace but does take large wrenches. The elements can be purchased at Lowe's or HD.
NOTE: I would recommend you replace both heating elements since they seem to go about the same time.
Jun 19, 2011 | Reliance Water Heaters
Pilot light not staying lit, changed thermocouple, start up proceedure normal until the pilot button released.
Some things to check:
Make sure the thermocouple is squarely in the pilot flame and that the pilot flame is large enough to envelop the thermocouple. A weak pilot can be caused by gas pressure or a carboned-up pilot orifice (where the gas comes out). The orifice may need to be cleaned. Ordinary automotive carburetor cleaner will work. Don't try to stick objects into the orifice - damage may result. If you need to perform this step, make sure the gas is turned off to the heater first.
Make sure the other end of the thermocouple is clean and tight in the gas valve.
Hold the pilot plunger down for at least a minute to be sure to give the thermocouple enough time to heat up.
Mar 15, 2010 | Water Heaters
Water heater sounds like its boiling and the water is cloudy and very hot
make sure the thermostat is pushed up tight to the tank and there is nothing between them. If all this is good replace the upper thermostat, make sure the new one is set between 110 and130 degrees. Make sure the temp. and pressure valve is working and not blocked up.
Mar 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My hot water heater is whistleing when i turn my hot water on it stops
make sure yor temp is set at 120 and make sure your water pressure is at 75lbs
Jun 08, 2009 | General Electric GE SmartWater Household...
No hot water
check the flue and make sure nothing is in it, nothing can be obstucting the flue or it will shut down on carbon monixide make sure nothing is in it if you have to take it apart do so it just slips together
Jun 07, 2009 | Rheem Tankless Hot Water Heater...
Rheem 92 gal. no hot water. breaker not tripping. lower thormostat reading no ohms. the upper thermostat is reading about 6 ohms. however when i turn power on the upper thermostat reads no voltage? Do i...
Have you checked to make sure that the elements are good by checking the ohms. Be sure that the power is off and the wires are disconnected from elements and then also be sure to check the ohms across the tank to make sure there is not a dead short in the element reading through the tank. If both elements are good then I suggest replacing both thermos then they will both be new and should work for you . Thermos can be problematic when trying to test them sometimes they won't always give you correct readings. Make sure you have the breaker off whenever you mess with a waterheater, and make sure you install the thermos correctly with the right wires going where they should.
Apr 19, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water not getting hot / Kenmore Economizer 6 / Electric
Did you check to make sure that the breaker is good on the unit? Check to make sure you are getting voltage. If not, check to make sure that the thermostat located in behind the panel on the heater is getting voltage and also sending voltage to the elements. If the elements are getting voltage but aren't heating, the element(s) is bad.
Mar 06, 2009 | General Electric GE SmartWater Household...
Hayward C-Spa XI 11 heater non operational
hi not coming from the US but from the UK. have you wired up the elements correctly?
you need to make sure there is power at the elements, you can do this by using a multimeter.
By physically disconnecting the elements & fitting a plug on them & plugging them directly into a power outlet, that way you can definately be sure that the elements are ok, but if you are in the US make sure its all to code?
Check the thermo( I am guessing by this you mean the thermostat?)
You can link this out just to make sure that the thermostat is not at fault. so by doing that you are putting the heater in a permanent demand, if that works then it could be the stat thats giving probs.
So you kinda get where i am coming from process of elimination here? or that if a timer is in an off position?
My hunch sounds as though it could be a pressure switch prob?
if you have wired the elements in right make sure your not getting a back feed & that its not showing you theres power when in esscence there isnt ?
Kindly
Richie
Dec 16, 2008 | Water Heaters
Water heater leaks on top
Make sure to use pipe dope(compound) or teflon tape on the threads. If you use the tape make sure to wrap the tape in the direction of the threads. Don't over do it with the tape 5 or 6 wraps should be fine. I prefer pipe dope myself....Joe
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
48 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
