Question about Toshiba 37HL67 37 in. LCD HDTV
TV will not turn on, just stopped working. Checked circuit breaker, outlet works, wiggled power cord at the tv junction. Nothing, just dead. Is it a power suppley? If so how muxh to fix
  • 558 Answers
Power pack is most likely culprit and it can be 500 dollars depending on alot of things.
you can check on Ebay
Posted on Jan 31, 2010
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
No power when television is turned on
1) test the outlet box and plug a desk lamp if work, if does the circuit is o.k if NOT reset the c.breaker from your home
2) test the power cord for open or break
3) see for a blown fuse inside and replace, or c.breaker tripped reset.
4) test for short in transformer+coil+filter+diode+rectifier and ground chassin.
5) test the Horizontal output for +125vdc +HVREC+FLYBACK+vertical output for 80vdc+all they go to the CRT. measure the color circuite +12vdc+other circuite+12vdc+audio 24vdc. see the block diagram oTHERWISE you must to the repair shop TV
God bless you
Jul 31, 2012 | Zenith Televison & Video
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I bought LCD TV 32"
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Apr 03, 2011 | Televison & Video
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
JVC AV-48WP55 won't pwer up.
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
Nov 28, 2017 | JVC AV-48WP30 48" Rear Projection...
TV doesn't turn on. All power sources working.
Check the main power cord for proper fit from the wall too the tv. Make sure the cord is well fitted in the outlet and the tv. If the connection is in standing and there's ac voltage coming from the outlet.......then it
may be a blown fuse or a dead power supply circuit with-in the tv. If so, the tv needs to be serviced.
Dec 24, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Dec 03, 2008 | Vizio GV42L 42 in. LCD Television
Toshiba 37HL67 37 in. LCD HDTV Logo
197 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
