Circuit diagram of power supply of scxi 1001
Cn i get the circuit diagram of power supply of scxi 1001 from anywhere. i have 2 check the scxi kit that i have. something is wrong with the power supply
    Problem Solver:
  • 8 Answers
I dont know how much it is of help, but I am giving you the link for scxi 1001 manual. The link is as follows :
http://rapidshare.com/files/93463249/scxi_1001.pdf
Posted on Feb 20, 2008
  • 979 Answers
Contact your respective MFGR for info. Some of it is proprietary, and therefore you must be an authorized servicer to acquire this info. However, you should be able to troubleshoot this box if you have any experience at all. Usually, the problem is in the regulation feedback loop...accordianman
Posted on Feb 19, 2008
95 Chevy blazer transmission fuse keeps blowing
One of the solenoids inside the trans is shorted . TCC,3-2 ,2-3 ,1-2 shift solenoids . Do you know how to test electrical circuits with ohm meter ? Find the PCM or a connector (which ever is easiest ) to get at ! Go here for wiring diagrams http://www.bbbind.com/free_tsb.html free wiring diagrams. Test each solenoid circuit . The fuse supplies power, the PCM - engine computer turns the solenoids on by supplying a ground . If you don't know how to do this check out this video ECM Inputs and Outputs Diagnosis you will find this wiring diagram at www.bbbind.com . this diagram is under engine ,subsystem -fuel controls .
w9zwhfrfacnsgaaaabjru5erkjggg==
Apr 30, 2016 | Cars & Trucks
Powering problem
Check plug first the one you plug in wall if there is a small black box at point were you plug in ,there is a transformer in there sometimes they short out .Check with multi meter if it is good then try schematic or Circuit diagram
Feb 07, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
How do I fault find my Velleman amplifier kit?
Something's REALLY wrong. Send me the schematic, and I'll look at it and TRY to help you.
Jul 26, 2014 | Velleman SA K8060 200 Watt Audio Amplifier...
ATX-300-12Z was hit with a power surge (thought we had a surge protector). Green light on power supply blinking at 2X/second. No power at USB devices (or anywhere else.) PC was on when surge hit.
There were 2 Switching power supply circuit inside the ATX PSU. There's a Standy PWM circuit whichSupply +5V to the PWM IC of the Main PWM. Stand by pwm still working or insufficient voltage, lower than +5V. This is the reason you still have Green light. Check or replaced small filter capacitor around 100 MFD 16V, open resistor or shorted diode that was nearest of the PWM IC..
Watch out for charge voltage on big capacitors.
Rleo
Dec 30, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Dec 04, 2009 | Protron PLTV3250 32 in. LCD Television
Megaworks THX 550 does not power up
I was able to repair my sytem using the guidelines from pouakai at (http://forums.creative.com/t5/Speaker-Systems/Successful-repair-of-MegaWorks-THX550-power-supply/m-p...
My system also would not turn on. The problem was on the power PCB - the one with the two large heat sinks attached. I found that the piece of PCB track joining the 2M ohm resistor (connected to the LINE-SENSE pin of the TOP243Y switcher) to the positive output of the full-wave bridge rectifier, was broken. This could have been caused by corrosion from the glue (which covered that section of track). I also replaced the 2M (0,5W) ohm resistor, just incase it was also to blame. The 2M ohm resistor is located under one of the two black heatsinks. I used a short piece of wire to replace the PCB track (from the large filter capacitor next to the resistor) to the 2M ohm resistor. Plugged everything back in, and it worked!
The circuit diagram given on page 21 of the TOP234Y's data sheet was very useful, and helped me understand how the circuit functioned.
I hope this is heplful for others who have this "no power" problem!
Aug 22, 2009 | Creative Labs MegaWorks THX 550 Computer...
Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
mladen@propilots.net
Mar 18, 2008 | Lowrance GPS
Computers & Internet Logo
269 people viewed this question
David Payne
David Payne
