Question about Honeywell Programmable Thermostat Heater
I am installing honywell thermostat rth111/rth221 old thermostat only has two wires red and yellow new thermostat has terminals marked Y,G,Rh and Rc with jumper,W. where do I connect red wire and also the yellow wire. I have a radiator type heating system will this work wth it?
  • 20 Answers
The red does go to RC, but the yellow should go to the W terminal, in HVAC W=heat Y=Cool, so aslong as the same wire is on RC on the t-stat, and RC on the unit, and same wire to the W on the t-stat as to W on the unit it should work!
Posted on Feb 02, 2010
  • 111 Answers
Connect y to yellow and red to Rc, the thermostat operates a relay that turns on the burner
Posted on Jan 31, 2010
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell RTH111/RTH221 I put de red wire ont Rh, but where do I put the black wire? Thanks!
If you just have two wires and it controls heat only put black wire on W, or W1 if there is no plain W
Jan 22, 2011 | Honeywell Programmable Thermostat Heater
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,458 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
