Question about Frigidaire Kitchen Ranges
Lock light is blinking / oven light on
We're unable to stop the lock light is blinking or turn the oven light off
  • 254 Answers
I would unplug it or turn the breaker off to the unit for at least 5 minutes see if this resets it or the code goes away, if not then usuallly the lock flashing relates to a bad lock assembly,, also if there is any control locks make sure those havent been accidently puches hope this helps
Posted on Jan 31, 2010
Says "locked' an unable to use, no buttons work
The child lock is on. Turn off the lock by pressing and holding 0 until the word Locked disappears.
To turn on the lock, press Stop/Clear and then press and hold 0 until the phrase appears.
The manual for the Jenn-Air JMC8130DD is available from http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC813&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
Feb 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
This cooker was fitted by Kitchens Direct last year, so is new. No manual was left by the fitters A power cut, throws the electronics out and the oven stops working. How do I get the light to stop...
Most likely, the digital panel just kind of locked up. The first thing I would try is to turn off the circuit breaker at your home's breaker (or fuse) panel for about 5 minutes and then turn it back on again. This should "reboot" it and hopefully the oven will get its brains back!
I hope this helps! :)
Dec 14, 2010 | Ovens
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 | Ovens
Lock light on frigdaire self cleaning oven
OK, this is not a good situation here. your Electronic Oven Control board is damaged. the logic sectors are faulty. The F-1 represents a major EOC failuer and, you will need to replace your EOC(clock) asap, if possible.
Jun 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven lock light
Oven lock is usually associated with oven cleaning. Last owner probably tried to clean the oven for you and didn't finish the cycle. Either finish cycle or turn it off (if possible).
Oct 03, 2017 | Maytag MEW5530D Electric Single Oven
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Oct 02, 2008 | Kitchen Ranges
Unlocking oven door??
Try pressing STOP/CLEAR, then pressing in and holding the door switch plunger for 6 seconds on the upper right hand corner of the door.
Sep 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Self clean light blinks, oven does not work
You were right. The locking mechanism switch somehow became jammed and the oven thought the door was locked, even though I could open the door. I didn't know if I was supposed to take the top off and moving the lever back and forth did not help. Finally I turned the oven on and just kind of jiggled the latch in the unlocked position. I kind of moved it back and forth furiously and the cleaning light stopped blinking and the oven light came on. I'm glad it is working now, but I will be manually cleaning my oven from now on! Thanks for your help.
Dec 25, 2006 | GE JGBP26 Gas Kitchen Range
Kitchen Ranges Logo
253 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
