Question about Crosley CCW5294W Top Load Washer
My crosley washer filled with water and stopped working. the water level light is blinking, but it won't finish the cycle. can you tell me what the problem is?
I have the model CAWC529PQ1... my washer goes thru the washer cycle but then stops working when it's time to drain... how do i figure out whats wrong
Posted on Aug 04, 2010
  • 1,531 Answers
There may be a problem with the pressure switch.there may also be a problem witht the lid switch.try and unplug the unit and see what happens.
the main control board would be the last thing to go out and need replaceing
Posted on Jan 31, 2010
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Crosley 1244 washer won't cycle
This indicates a faulty lid switch.
Apr 27, 2012 | Crosley Washing Machines
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Washer will not fill but immediately goes to the agitation cycles. I figure the water level sensor?
yes! check and reset or change the water level switch that sounds like a good place to start
Jan 19, 2010 | Crosley CAWC529JQ Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Crosley CCW5294W Top Load Washer Logo
417 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
