Hooked up my hard drive to another computer set as slave. How do i start saving my data?
  • 1 more comment
  • jimmy_hernan Jan 31, 2010
    was not in drive D but it was in my bios as slave
    i tryed hooking it up to drive D but it told me i have to format
    if i did this all data will be erased i dont want it erased just
    backed up because i am just trying to save
    what i can so i can add it to a new hard drive what would be another
    solution so i can copy its data to drive C
    its not showing on, my computer, only bios as slave why is that
    it wanted me to format any way i dont have to do that just in case it doesnt get saved in i loose everything
    Sergeant:
  • 244 Answers
Hi Jimmy,
If you are saving a back-up data to the 2nd harddrive (slave). Just copy paste it, or drag and drop it, save all the files on the 2nd hard drive. Make sure the drive is detected.
Hope this helps.
Posted on Jan 31, 2010
  • 3,940 Answers
You open my computer or windows explorer and browse the drive (it should be D:) for the files you want to save. Then copy the files to the C: drive of the system, a USB drive or burn to a CD or DVD.
During the copy process, you may need to take ownership of files
http://support.microsoft.com/kb/308421
If you have hidden files, then you will need to unhide them
http://www.bleepingcomputer.com/tutorials/tutorial62.html#winxp
  • IQUIT Jan 31, 2010
    If you are getting prompted to format then the data is not accessible. You will more than likely need to send the drive to a data recovery service such as drivesavers.com if your system was not recognizing the drive as having data
360 harddrive
Is this a new hard drive that you are fitting to a desktop PC?
If it is a new - empty- hard drive it will have to be formatted before you can install Windows.
If it is a hard drive that you are fitting as a slave you may be fitting it on the wrong part of the IDE data cable, or if SATA, on the wrong motherboard connector. IDE data cables have many pins and are grey and wide.
On an IDE cable you may have 3 connectors. One which fits the motherboard, and 2 connectors to fit drives. The connector FURTHEST away from the motherboard is the MASTER. The middle connector is for the slave.
On the rear of a hard drive you also have 'jumper connectors'. The location of these connectors sets the drive as either master or slave. On an IDE data cable the master drive must be at the cable end with the jumper connector set to master (or 'cable select'). The slave drive - on the middle connector - must have its jumper connector set to 'slave' (or 'cable select').
If you are using SATA, the hard drive should be set to master or slave.
However, it would appear your computer IS recognising the drive. To check, restart your computer and press the delete key as it boots up (or it may be another key ..it tells you on the start up screen which key to press to access the bios settings).
Access the bios settings and look for the disk information. It will tell you if the disk is detected and whether it is a primary master or primary slave. You can always try disconnecting your dvd drive (power off the computer first..) and fitting the hard drive in its place. Restart the computer and go into the bios settings again. Is the drive now recognised as the secondary master? It well may be just incorrect location on the cable/jumper settings/where the cable is connected to the motherboard.
If it is just a single hard drive you have and it is new, Your computer will tell you that it needs formatting before you can install an operating system or software.
If it's a second hand drive you are fitting, your computer will not boot up even if the hard drive already has Windows on it. You will have to reinstall Windows from a dvd.
If it's your existing hard drive which had been previously working ok, remove the data cable and reconnect it. It may be a 'dry joint' causing the problem. If disconnecting and reconnecting the cable on an existing hard drive does not work .. begin to suspect a failing hard drive
Jun 08, 2013 | Transcend StoreJet Computers & Internet
How do I add a slave hard drive to a computer
Is it an ide (flat wide data cable & 4 cable power cable) hard drive? There will be jumper pins near the data cable socket to set one as master and the other as slave.
Jan 05, 2012 | Dell Computers & Internet
I would like to use my old 40 gb Western Digital Harddrive for a secondary data drive on my Desktop computer. When I hooked them both up and powered up the computer wouldn't boot, I assumed it was because...
http://www.lyberty.com/tech/hard_drives/WD_Caviar_WD400BB_specs/index.html
Above is the link to set the jumper on the 40GB to Slave.
Also, before it boots, try to get into the BIOS setting and make sure your compter can see both drives. If not, double check jumper settings for both drives. Turn off compter and change settings.
When computer can see both drives in BIOS, save it and let the compter continue to boot.
Hope this helps.
Jan 04, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
External maxtor isn't recognized on XP
Since you have important files on this drive, do not waste a lot of time with troubleshooting. If your drive is about to go out, you can put it over the edge that way and kill it.
Just to be sure, I would plug the drive into 1 other computer just to make sure. If you get the same thing, the problem is definently with the Hard Drive.
If this is the situation, I would take off the outer case to reveal the regular hard drive inside. You can hook this hard drive up to your computer as a slave and copy the files off. If your computer will not read the drive as a slave, and you have double checked the jumper settings and cable position.....you can try a program like "Get Data Back" to try and recover data off the bad/corrupted hard drive.
Jun 02, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Maxtor slave settings to recover data
Leave your original drive in your PC set as master, set the T1600 to slave
Open your desktop, click my computer and click C drive, reduce the window so you can slide it to one side, click my computer again and then click G drive if that is what the slave is called. Make a new directory in C drive and give it a name, Drag your files over and drop them into the directory.
Nov 09, 2008 | Maxtor Hard Drive
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Mike
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Data recovery
Remove the hard drive. Put it into a working computer as a slave drive. You can then access the hard drive from the second working computer to save your data.
Alternatively, buy a 3.5" hard drive enclosure (like this one: http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&MSCSProfile=3C79F0C7EA3162B2D7ADAC57314A0E6A590377F958863102EDBCF732E27F5F9388E0A55795B25749B2DCA82F3E403B752755F32E5B789E64D63C62D3278A64336587C84A5489154B0DA4873945D091EB3A885032FFFAB317F456B0258935E9F951596CC147AFD5FE7493D1CB0BD503269C7C090911A34F48&sku_id=0665000FS10092821&catid=11288 ) and put it in there, then you can plug that into another working computer via usb and access your files that way.
Third alternative, boot to a rescue diagnostic disc such as the Ultimate Boot CD http://www.ultimatebootcd.com/ and you can access your hard drive from there. This is an option for advanced users, since a lot of the diagnostic tools are command prompt driven and require you to understand a little about the insides of the computer. You will need another external hard drive or usb key or something to copy your data to.
Jan 25, 2008 | Computers & Internet
21 people viewed this question
jasbo
jasbo
