Question about Sunbeam SLP3310UM Heater
It has just quit working completely weve had this only one month and it makes no sense to pay what we did for only one month we want a replacement i will never buy another sunbeam product i hope everyone else sees this
  • 111 Answers
Did this heater get knock over, sometimes the safety switch gets hung up inside, cheap bi-metal switchs that cycle the heating element burn, power supply, bad plug or recepticle, heck put a high amp relay in and a wall thermostat,it'll probably say made in china on the back
Posted on Jan 31, 2010
2001 mazda 323f car
Check your distributor cap and rotor, make sure the firing order is correct. Reset timing and start vehicle. Make sure the spark plug wires are ok. Problem should be gone.
Dec 04, 2013 | Cars & Trucks
Hotpoint oven thermostat replaced again a few months ago now oven working but thermostat bulb not. Can this be replaced and how ? Thanks
Depending on which thermostat you are talking about , the main oven thermostat is complete with with sensing bulb, so is replaced as a complete unit.
The other stats, including over heating stat, and cooling fan stat do not have a sensing bulb, they are a bi-metal device, and can be replaced individually.
Nov 14, 2010 | Ovens
2002 Toyota Avalon XL - The turn signals and emergency flashers blink a few times and then quit, about half the time. They are turned completely on, not to the lane change pressure point. When they quit,...
Most likely is the electronic turn signal flasher unit. When it is working listen for clicking noise it makes that will make you aware where it is under your dash. Try parts store or dealer to buy unit.
Jun 06, 2010 | Toyota Avalon Cars & Trucks
GE Harmony Dryer dries fine one time won't quit sensing the next
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
Jun 19, 2009 | GE Profile Harmony DPGT750EC Electric...
95 Saturn SC1 Transmission Problem??
What actually is wrong with the car? What is it doing?
Apr 06, 2009 | 1998 Saturn SC
The freezer is working but the fridge isn't cooling. Numbers in fridge door are: WRN38RWG6 DA68-11043J
Hi sarahcox36,
welcome aboard!
You say: The freezer is working but the fridge isn't cooling.
first think you have to look at is if the freezer is packed full or the frozen food is covering the air vents in the rear of the freezer not allowing the cold air to circulate back to the fridge!
They share the cold air and must have that circulation for the two to work properly.
Please check this.
Next,
Under your fridge is the small black tubes that run bck and forth next to each other.
they have the freon running through them that circulates to and from the compressor!
They may be covered with dust from years of not being cleaned! Which will keep the heat in and cause the fridge to stay warm !
I've seen where they were caked with 2-3 inches of dust and not visible! After 12 hours it was better and 24 hours great!
They should be gently cleaned every couple of months with a refrigerator brush that you can buy for 5 dollars at a hardware store .
Let me know that one of these two are the problem and get back to me!
How old is the fridge?.... READ Repair or replace?BELOW!!!!!!!!!!!!!!!!!!!!!!!!!
Bless You
Huuum
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 20, 2008 | Whirlpool Refrigerators
I have a Whirlpool side by side fridge. The alarm is sounding with the display panel showing two dashes on the freezer control. We have tried turning it off & on which only seems to rectify it for a...
Hello BLakeman,
Did you try turning it off...And then unplugging it for 5 minutes?
Or if you can not reach the plug, you can turn it off and then turn off the breaker for 5 minutes!
This can reset the system completely like we sometimes must do to our computer when they get unruly!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Repair or replace?
Thank You, HUUUM
Ice maker just quit making ice. Defrosted freezer, changed water filter, changed the solenoid. Please help!! thanks
Hi chjnt,
What is the model and age of the fridge?
If it is a side by side and you did all that for it already, perhaps it may need a replacement ice maker.
They are not complected to install!
Let me know any other info you may have.
I think it needs a ice maker replacement!
Please do not forget to give a rating before you sign off!
Thank You, HUUUM
Here is and interesting report!!!!!
Repair or replace?
Sep 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
Hello bnelson488,
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Huuum.
Here is an interesting article I just read.
Repair or replace?
Sep 04, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not working
Hello dooz127,
You have a coolant leak some where.
How old is your fridge?
huuum,happy to assist you!
Repair or replace?
Thank You, HUUUM
Aug 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sunbeam SLP3310UM Heater Logo
345 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
