Question about Carrier Heating & Cooling
WHAT UNITS USE THE HK38EA004 CONTROL BOARD? WHICH CONDENSER UNIT? -- PERFORMANCE SERIES I THINK IT'S A 4-TON BUT NOT SURE THE PANEL W/ INFO IS MISSING. I ALSO WANT TO KNOW HOW TO TELL IF THE BOARD IS ANY GOOD AND IF NOT CAN IT BE FIXED?
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
farfield
  • 462 Answers
SOURCE: Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to rep
A new unit will be 13+ seer unless you can find someone that has replaced a compressor or has one left over from pre 2006 stock. Our wise Government with all its resources decided that we aren't smart enough to turn off the lights to save energy, so they chose to end the med and low price lines. And the same bunch of smart ones decided that now R22 because of its chlorien content being bad for the air (5% of what R12 was) so we have R410A and others that no one knows how much cancer or daMAGE THEY WILL DO OVER TIME. So now if you replace your AC unit out side with a new one be sure its compatable with the refrigerant inside and beware soem manufacturers wont stand up to full warranty if you dont buy an indoor coil and rerplace it too.
We get what we deserve in Washington DC and if our guy didnt support this stuf too many other folks guys did. We just dont talk about it enough. AND WE SHOULD. But then again you like me are probably RITCH. So we have to give up our wealth to the government so they can redistribute it and buy more votes. And we can stay working too much to talk about it.
Just burns my back side like a 4 foot flame.
Read tween the politics and you'll get my recomendation.
Buy your self a compressor and get someone qualified to install it or see if the old goodman one will interchange easily.
Posted on May 12, 2009
philbran
  • 242 Answers
SOURCE: a/c unit not cooling
if it is making strange noises during operation it is going out on high pressure due to the condenser fan not running , check the capacitor for the fan to make sure it has not expanded also check if motor is getting proper voltage , is capacitor is good and motor has proper voltage supplied then you have a bad motor and should be replaced with new capacitor.
Phil
Posted on Jun 11, 2009
james3751
  • 614 Answers
SOURCE: Can Air Handler !1/2 ton run with 2 ton
Its done all the time. It is sometimes better to do this because you run a colder coil and rmoves more humidity. The newer unit have variable speed fan and run slower to do the same thing. Remember the lower the humidity the higher you can raise your tsta. Example In arizona at 95 degrees you dont feel the heat as much because of the lower humidity. Its ok to do so. You get more btus out of your unit that way. Rus. I have dozens of units with air handlers 1/2 ton smaller...
Posted on Jul 18, 2009
  • 9 Answers
SOURCE: How many tons is the condensing unit serial # 10AJ...
3 tons. 12,000 btu per ton divide 36 into 12 = 3 tons
Posted on May 22, 2010
Comfortmaker
need more info on condenser itself the model number not coming up but the nomenclature u gave looks to be a 4 ton unit. why I say that is the 48 normally represents the btu's 12000 btu per ton. so 48 represents 48000 btu 4 ton. now this depends on your house 400 square feet per ton is a rule of thumb without doing a proper house inspection. how many windows type of windows all kind of stuff. so 4 ton is roughly good for a 1600 square foot house depending on all kinds of variables. if I can get a full model even if it shows ----00-- something like that I can give you a for sure answer. u may even get an r-22 unit which u can buy only as a dry unit companys still make them but can no longer ship them with r-22 in the they come charged with nitrogen which will save you a few grand on install because you don't have to change the indoor coil to a proper sized 410 a coil or the lineset. be aware of contractors who tell u to keep the indoor coil they will add a expansion valve and flush the lines with r-11 or rx-11 flush u wont get the efficiency or 100 percent working condition of a mix mash system.
Oct 20, 2013 | Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
What are twinned units?
Twin units can be two airconditioner condensers and/or two furnaces. Most manufacturers make a twinning kit that will wire two units together to operate simultaneously by one thermostat. At times, one may operate as a first stage of heating (cooling) and then the other unit can operate as second stage. Twinning unit are beneficial in commercial buildings where the load conditions vary constantly. For instance, if you twin two 4 ton units together. On a nice cool day, you may only need 4 tons of air conditioning. So, the thermostat will only turn on one unit. On a hotter day, you may need 8 tons of air, so the thermostat will turn on both units. In case you are thinking about doing this, the biggest mistake in twinning units together is using a common return air for the furnaces. Make sure you separate the return air cavities and ductwork for both of your furnaces If you don't have separate returns, you have the possibility of one of the blowers starting backwards. (talking form experience LOL)
Aug 13, 2011 | Heating & Cooling
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
Can't identify ton rating of condenser unit
the model number tells me it's a 4 ton. the 048 is what it gives it away. 1 ton is 12,000 btu's . 4 ton is equal to 48,000 btu's
May 23, 2009 | Heating & Cooling
What is the tonage of model 108jd30801 weatherking
I am not sure but I think it's somewher around 21/2 to 3 tons.
Mar 26, 2009 | Heating & Cooling
Condensing unit
the 48 indicates 48,000 btu's. 12,000 btu's = 1 ton of cooling. this unit is a 4 ton condenser
Mar 15, 2008 | Heating & Cooling
Heating & Cooling Logo
101 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
