2003 Volvo S40 Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't know what a particular warning light is. It came on today; it looks like a circle with little lines coming out of it. Sort of like a "light bulb" idea symbol.
  • Bartone
    Bartone Oct 15, 2018
    I hope that we all be patient and I want to present you this servicehttps://best-vegas.com/best-shows/absint... that will help every potentiel user to make a choice in Las Vegas show. I hope that you will be glad and find something useful for yourself.
oneStan
Level 3:
  • Master 617 Answers
  • Posted on Jan 31, 2010
oneStan
Master
Level 3:
Answers
617
Questions
0
Helped
206724
Points
2081
A circle with an exclamation mark is usually the low tire indicator (that symbol is a tire and a tire gauge). sometimes when the temperature drops down, one of the tires will show up as low & later in the trip when the tire warms up, it will read correctly. Or, you can just have oone that is too low & need air. good luck
1helpful
I have a warning light on that looks like a circle on a 1990 volv
this means the brakes are low, have your brakes checked, hope this helps.
2helpful
3answers
What does this light mean on my dashboard?
this sounds like the Traction/Stability control and ABS warning lights, they are art of the same system and come on together.
Dashboard warning light as a circle with wavy lines through it
This is probably the coolant level sensor indicator for the antifreeze reservoir.
Warning lights on land rover dicovery 1993
A circle with lines around it - depends where it is -
If its a top left light, then it should be a circle with an exclamation mark in the middle, and two lines running part way round the outside (1 to 5pm and 7 - 11pm). Thats the handbrake and brake fluid light which comes on for about 3 seconds when you start the engine ... if it comes on at any other time - seek help.
If its top centre, and has ABS in the middle, then its the anti lock braking light. Similar to above, lights up for a few seconds at start.
Muffler with lines coming off it - are they pointing outwards from the circle, (with a thermometer in the middle = transmission oil temperature guage), or are they on the left and all parallel (which would be main beam indicator, which lights up blue when on)
5helpful
3answers
Meaning of warning light
It might be that the tires are under-inflated mine does it too and thats what mine means
2helpful
2answers
Not sure what the icon on the dashboard was signalling
Semi-solved. It looks to be some sort of headlight warning. Fog lights?
I'm still investigating.
4answers
Warning light?
If it's round with a line down the middle, then it's a fault in brake system warning. You should check your brake fluid level.
Warning light
sounds like the cruise control on light
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
