Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I am trying to clean the oven,
I am trying to use the self cleaning oven. It is all push button won't work can you walk me through how to do it. It bas the digital clock on it classic series. thanks for any info.
  • 1,531 Answers
You can try and hold the door closed by hand and push the self cleaning button.and it might work
if that does nothing for you there might be a problem with the door switch.
the other likely problem is a bad clock timer/main control panel
Posted on Jan 31, 2010
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 | Ovens
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
I have a Kenmore gas range model # 7907578890. I pushed the clean button to clean the oven, door locked and cleaning started briefly then stopped. Door stayed locked. Now oven won't respond to any buttons...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 18, 2011 | Kenmore Ovens
I have a GE oven and when I try to clean it, I push the "clean button" and the oven starts beeping and the door button flashes. What do I do?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Dec 27, 2010 | Ovens
I am trying to clean my oven. I pushed the cleaning button, it locked and said it would take 4 hours. One hour into it, it is beeping F2. What does that mean?
It means that somwthing went bad in there.... shut it down and read this tip....
Before you go working too hard to get your oven to go into the self clean mode (self destruct mode)....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Nov 13, 2010 | Ovens
Trying to clean my oven. When I push the clean button it works for a couple minutes and then it starts beeping and an f5 code appears.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do you get a Fridigaire self-cleaning oven to self-clean?
most ovens have one button clean cycle . remove racks and close door push the clean button and it should lock the dooor and clean for 2.5 hr . then cool down befor you can get back in . if this does not work i will need a model # to help you more. mm
Aug 11, 2010 | Ovens
Self clean results in f9 and beeping
heatman101
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
121 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
