Question about Dell Dimension 5100 (D51L1) PC Desktop
Will not boot up
Hi
My Dell dimension will not boot up.  As soon as I turn it on it goes directly to 3 and 4 bypassing 1 and 2.  I'm not technically minded so can anyone suggest what might be wrong.  I just have a blank screen on the monitor.  It did start once and I immediately got a message requesting me to restart to finish installing updates.  I checked for software updates and the computer just shut down never to restart again.  Any advice would be greatly appreciated. Thanks
  • Damiands Feb 18, 2008
    Hi rey jr
    Thanks for your solution but I can't even get to the stage of reinstalling software because although the cd tray opens I am unable to boot from the cd.  I note that the fan does not appear to be working and wonder if this is part of the problem.  I have a completely blank monitor screen with no prompts and the F keys don't work :-(((
    Damian
  • 149 Answers
Hi there, check the cmost setup for hard drive detection. if detected you may have a software prob., try to re-install your operating system, i.e. windows, hope you can save your documents files before you can install new operating system. ty
Posted on Feb 18, 2008
  • Redentor Rey Jr
    Redentor Rey Jr Feb 18, 2008
    hello Damian, try to identify wich part is failling, remove the hard drive, the floppy drive, or any pheripherals with in., turn it on if it will work, if still same prob. you may have a board problem. do some test and check up. ty
My Dell deskop when turned on only goes to the Dell slash screen then the screen goes black. Will not go to the windows screen.
Try these options:
1. Reseat your hard drive - unplug the ide cable from the motherboard and plug it again
2. Reseat the memory - remove and put it back again
3. Try to go to safe mode - while starting, press the F8 key to see the options
4. On the otherhand, you can select boot from the cd and use your Dell Diagnostic Utility and run hardware tests and see whats wrong..
Dec 01, 2010 | Dell Dimension 4500 PC Desktop
Dell Dimension tries to boot, blinking cursor
first check the BIOS settings whether the first boot device set to be hard disk and no CD in the CDROM and also ur system is virus free
Apr 19, 2010 | Dell Dimension 3100 PC Desktop
Dell dimension 5510 it will not turn on, no
1/10th a volt? Nope.
Bypass the Power On switch. See if you have a bad switch first.
Then test the power supply. If the power supply comes on by bypassing the Power On switch, I'll bet you have a weak 12 volt voltage power rail.
1) Yellow wires are 12 Volts
2) Red wires are 5 Volts
3) Orange wires are 3.3 Volts
4) ANY Black wire is a Ground wire
They do sell power supply voltage testers, should you not wish to use a multimeter set at DC volts.
(0 - 50 Volt scale)
I prefer a multimeter.
A) ALL the light use less than 1 Watt
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 55 to 125 WATTS.
You have to turn the power supply on, by jumping the Soft Power On wire to any ground wire.
This is also the way to bypass the Power On switch, to see if the switch is bad.
Do you wish to proceed?
Jan 15, 2010 | Dell Dimension E521 PC Desktop
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. rain_catcher000_6@hotmail.com.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Wont boot correctly
Typically, a system that won't pass POST (Power On Self Test) will beep in a pattern indicating what the problem is. Here's the beep codes for Dell systems:
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Jul 08, 2008 | Dell Dimension 4500 PC Desktop
Bleep on start up with black screen
1-3-2 is indeed a Memory error.
The Diag LEDs on the front panel should be 34 too
Try each RAM module individually, and insure that when you seat the ram, you do the following:
  1. Unplug power then press and hold power cord for 10 seconds to bleed stored power in MB.
  2. Remove ram using levers on slots,
  3. When installing ram, ensure the levers are back, press firmly with both thumbs to seat RAM until levers snap up and lock, do not pull the levers into locked position
  4. restart system.
If problem goes away with one RAM module, replace that RAM, if problem exists will all RAM in all slots, then replace Motherboard
Jun 17, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
48 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
