Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Linux internet connection
I have to connect wi-fi internet with my laptop i hav win-xp and linux in win-xp net is running good but how to connect in linux is there need any RPM or any plz tell me d procedure
Configure
Posted on Mar 06, 2008
Dkzhsgfs
Posted on Mar 02, 2008
Don't know how to connect to my home wifi
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Mar 11, 2014 | Acer TravelMate 2480-2779 Notebook
HOW DO I SWICH THE WIFI ON
Which model acer ???...
Aug 13, 2013 | Acer Computers & Internet
Lost internet connection linux mint 14
Installing your wireless driver on a Linux distribution is only half the battle.
Once it's installed, you have to configure it.
This means adding the network name, or SSID (service set identifier), and the passkey for your wireless network.
In older versions of Linux, this had to be done with the "iwconfig" command line tools.
Luckily, Linux Mint has incorporated a graphical utility for configuring your Ethernet and wireless adapters.
Open the "Control Center," which will be found under the main program menu on the bottom right of your computer screen.
Click the "Network Connections" icon under the "Internet and Network" section.
Click the "Wireless" tab in the "Network Connections" window.
Click the "Add" button.
Type the name for your wireless network in the "SSID" text box.
Choose one of the options under the "Mode" drop-down list. Most users will choose the "Infrastructure" option.
Click the "Security" tab.
Choose your network's security protocol from the "Security" drop-down list.
Type the key for your wireless network in the "Key" text box.
Click "Apply" to save the changes.
Click the network connection icon in the task bar. It will look like two computers and can be found next to the clock.
Click on the name of your wireless connection to connect to the network.
http://www.linuxmint.com/wiki/index.php/MintWifi - The_network_manager.
Activate a Wi-Fi Card for Linux Mint
Log into Mint as user root. Launch a command shell, either by logging in in text mode or by launching a Terminal window from the graphical desktop.
Type the following command into the shell:
iwconfig
Press "Enter." Make a note of the name chosen by Linux Mint for your Wi-Fi card it will be the only word displayed flush with the left edge of the screen.
iwlist wlan0 scan
Replace "wlan0" with the name of the Wi-Fi card you noted earlier.
Press "Enter."
Mint will display a list of the wireless networks in range that you can potentially join.
iwconfig wlan0 essid library-wireless
Replace "library-wireless" with the name of the network you want to join, from the list generated by the "iwlist" command. Linux Mint will join the network.
At this point you can browse the Web and access the Internet in other ways via the Wi-Fi card on your computer.
http://linux.die.net/man/8/iwlist
http://linux.die.net/man/8/iwconfig
Getting Started with Linux Mint
http://linuxgazette.net/137/lazar.html
Aug 07, 2013 | Computers & Internet
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
Wi-fi connection
1. First, you have to make sure that the Wi-Fi of your laptop is turned on.
2. Make sure that there's an available wireless network in your area so that you can test if the computer can detect any available network.
3. If you're running Win XP, right-click the wireless icon on your system tray and select "View available wireless networks"
4. If you can't detect any wireless network, right-click the wireless icon on your system tray and select Open Network Connections.
5. Right-click the Wireless Network Connection icon and make sure to enable it.
6. If it's already enabled, try to disable it and then re-enable it.
7. If you can't still detect any wireless network, try this:
- Click the Start > Run > type msconfig > hit Enter
8. Locate the Wireless Zero Configuration and click on it once.
9. Once it's highlighted, locate the Start button on the upper left hand corner of that screen.
10. After starting the Wireless Zero Configuration (WZC), try to detect the wireless network again.
Apr 08, 2009 | Advent 4211c Notebook
HW CAN I GET WI-FI DRIVERS FOR TOSHIBA SATELLITE L45 S-7423.
download the driver from th www.hp.com. type ur model number and select the operating system u r using and download the driver u want......
Feb 12, 2009 | Computers & Internet
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
Wi Fi driver downloading
Yes that should work fine, just as long as you download the driver for his card and his OS.
Sep 21, 2008 | Computers & Internet
Not connecting to Internet in Acer 4720z
cheak for firmware update on roughter software for vista ect ok thx nick
Feb 06, 2008 | Microsoft Windows Vista Ultimate Edition
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
73 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
