Hoover 2300l wont spin dry
Hoover 2300l 6.5 kg top loader wont spin dry
  • 3422 Answers
SOURCE: hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Posted on Jan 30, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
SOURCE: Spin Dryer doesn't work on Hoover 500M
Most probably the solonoid (also called brake motor). This is a 5 rpm motor that activates the drum to spin. I just replaced it two days back in my machine (Model 500M0AUS - you'll have to be specific when ordering or better take the old one to the spare part shop) which had a similar problem. The new soloniod I bought had a shorter cable length so I had to improvised when fitting. If soloniod is the problem then make wure the steel brake lever tooth fits perfectly in axle groove when you finish replaceing it. Do the replacement when the machine has fully stopped after completing its wash cycle.
Repair technician quoted 250 while the solonid costed me only 86. I did not charge labour to myself:)
Hope this is helpful.
Posted on May 29, 2010
  • 713 Answers
SOURCE: hoover top loader 750lc about 8 years old
Hi just read your posting.Now the only way to drain your machine if it is not draining is to do it by hand with a small pot or bucket. Do you hear a small click when you close the lid slowly?If you do then that is the lid switch.It will not drain if your lid switch is not activating.Did you wash a big load before the problem started?Also could be a faulty or jammed drain pump.I can guide you throe the removal of the pump to see if it is the problem if you have some tools available.Please reply after you have tested the lid switch and I can guide you throe the rest of the repair if needed.
Posted on Jun 05, 2010
Hoover 2305L goes through all cycles well.does not spin fast enough to dry clothes.
how old is the 7 kg washing machine
should be direct drive to the drum not a belt drive
the motor could be wearing out
are you over loading
May 11, 2016 | Hoover Washing Machines
Hoover 750L top loader washing machine
Goodluck,
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Electra 535 Dual Spin - I`m trying to discover what the capacity of this machine is, the manual supplied with the machine gives all spec.s apart from its size. ie is it 6, 6.5 or 7. kilos...
From what I remember, the 535 is a 5.5 kg machine. The best way to load any front loader is to have the tub full but not packed. Its the safest. As for weight capacity, due to Australian Standards testing, machines have to state what load they will handle with a certain volume of water and power usage, but any front loader, load it up but dont pack the clothes in and you will have the best efficiency. By the way, the clothes are measured dry weight..
Jul 31, 2011 | Hoover Washing Machines
Hoover top loader washes &
Check the lid safety switch.
Apr 01, 2008 | Washing Machines
Washing machine trouble
i need more info but can help front loader top loader brand etc
Dec 30, 2007 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
