Question about HP PSC 1315 All-In-One InkJet Printer
Printer says offline everything checks out
Printer says offline everything checks out normal??
Don't know what else to try
Thanks
    Problem Solver:
  • 9 Answers
Just chek for the the printer ikon in devices and printers(windows 7)..printers(vista) or printers and faxes(xp) from control panel..right click on the printer ikon and select the option which says "use the printer online"..see if the issue gets fixed..if it still persists..delete the printer ikon..insert the printer cd..do not run the file..just open it..look for the folder "util"..from yhere look for "ccc"..from there chek out l1 uninstallation and after that..run the printer cd and do add a device..let me know whether it worked or not..thanks
Posted on Jan 31, 2010
My printer keeps going offline. What can I do to get it back online?
I understand your Printer is offline on your Windows 8 computer.
The easiest thing to do is just rebooted everything. Turn off router, computer and printer.
Wait a few minutes and turn on router, computer and printer.
Before trying to print make sure there is nothing waiting to be printed. Right click on your printer and see whats printing. Remove if anything there. Try to print again.
If the printer still showing offline try installing and running HP Print and Scan Doctor.
Download and install at this location.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&jumpid=ex_r4155/hho/ipg/ccdoc/p...
Let me know how this goes.
Thanks
Mar 23, 2016 | HP PSC 1410 All-In-One InkJet Printer
Hp laserjet 4000 printer always saying "off line" and not printing what could be the problem
Please Clarify, does it say offline on the printer itself or on your printer driver. If it says offline on the printer itself, normally pressing the go button should put it online. However, at the age of that printer the buttons could be dirty/worn out, I have had control panels fail quite often as of late. If it is saying offline on the computer driver then that is a whole different set of issues and I would need to know what operating system you are running.
Jul 20, 2014 | HP LaserJet 4000 Printer
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
When I try to print I get the message that the printer is off line.
Please confirm your printer is plugged in and powered on. Next you should check your printer cable. If well plugged in and the the offline message persists, the you should try another printer cable, you know is working well. The fact is everything points to your printer cable if the printer is powered on. You may also go to your printer folder and right click on your printer icon th see in the pop up menu for any options for online/offline. If you see any select online. Otherwise you need to try another cable.
Good luck & God bless!
Nov 13, 2010 | Epson Stylus NX515 All-In-One InkJet...
Vista says CANON MF4370dn printer always offline? IP addrs issue?
first of all, download updated driver from software.canon-europe.com and install ( before install, remove old drivers and programs)
and if appears again, change your network cable.
Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
Offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
Apr 27, 2009 | Office Equipment & Supplies
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
116 people viewed this question
Seeker5211
Seeker5211
