Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer works great but food is spoiling and not cold enuff in fridge. dosent seem to be air flowing out of vents in the side in fridge. is there a fan that quit or could it need freon
  • 1,531 Answers
When you fridge is running open the freezer door and listen for a fan there may aslo be on ein the fridge compartment,also look for frost build up on the back wall of the freezer.if there is ice build up you need to defrost it.when the unit is in the cooling mode and you do not here the fan running on the inside of the unit the the fan needs to be replaced.
Posted on Jan 31, 2010
Freezer works, fridge side not cool
OK if the fan was replaced and the vents are open there has to be a restriction of air flow over evaporator coil causing the lack of air flow. On some models like yours there is something called an auto damper between the freezer and fresh food compartment and the damper is operated like a thermostat bulb on it's own solo. The best way to test them is to remove and place the thermostat bulb or tube coil into cold or hot water. I will gather more information for you as we go along here. Thanks, Sea Breeze
May 14, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
No air flow in fridge compartment,rfeezer working but not as well as normal
you may have ice build up at the freezer section. kindly look at the back side of the freezer if you have ice build up.
if you do then you have problem with defrosting.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
Freezer at 10 deg, fridge at 50
haier refrigerators have been known to have the cold control go bad. it only sense's the temp in the fresh food section so that would be why the freezer is still ok. The problem is the control is cutting out to fast and not letting the temp go lower. from what you said i would take that there is good air flow between the freezer and the fresh food compartment. so the only thing it could be is the cold control. I would replace it and you should be all set.
Aug 10, 2007 | Haier HTQ21JABWW Top Freezer Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
136 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
