Question about LG Over-the-Range Microwave
Changed bulb in whirlpool microwave model mh1150xm know it wont work, i have clock and can set timer and cooking power but when i hit start it wont come on
  • LG Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too, as well as other functions.
Posted on Jan 31, 2010
Hi how do I set a hisense microwave clock,its been giving me a hard time to set it,please help
I know there is a cook timer and a clock ....Hit clock ...set time..then hit clock again....That's how mine works... Hope that helps
Aug 14, 2017 | Microwave Ovens
MY CONVECTION OVEN IS NOT WORKING. LOW TEMP AND FAN NOT ROTATING
Whirlpool MH1150XM-series models do not have convection cooking.
Aug 19, 2010 | Whirlpool MH1150XM Convection/Microwave...
We changed the oven bulb and now the microwave doesn't work. The power comes on and the clock can be set, but when you enter a time for cooking the timer counts down but the microwave doesn't come on.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
It may just be a fuse. Some models have more than one.
Otherwise, I would suggest that you check all the door switches and mounts.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Otherwise, feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & DIY help and/or an estimate.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Dec 05, 2009 | Whirlpool MH1150XM Convection/Microwave...
Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Nov 12, 2008 | Whirlpool MH1150XM Convection/Microwave...
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Whirlpool MH1150XM
Full details of our service are at http://www.microwavedisplay.com but if you still have questions, please reply back.
Apr 09, 2008 | Whirlpool MH1150XM Convection/Microwave...
Microwave Hood/Combo
This is a common problem with the control panel assembly, which we repair nationwide for $39.95. This is most often caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. If you or a friend decide to disassemble it to send the control panel in for repair, we have *critical* safety & disassembly, info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 22, 2007 | Whirlpool MH1150XM Convection/Microwave...
Complete functioning control panel but nothing works.
This is a problem with the control panel assembly, which we repair nationwide for $32.50 postpaid. Sometimes the bulbs short when they fail, and that damages the control board. This also can happen when bulbs are removed or installed without first unlugging the oven or turning off the breaker. For critical safety & disassembly info and other details of our service, see http://tinyurl.com/yzjozk
Jan 16, 2007 | Whirlpool MH1140XM Microwave Oven
LG Over-the-Range Microwave Logo
186 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
