I have an E:13 error light and I've tried Refresh and running it through empty many times. Please help
  • 1,531 Answers
This is a water leak in the tub or the air bell.
the air bell is part of the unit that is connected to the pressure switch that stops filling when it gets to the righ amount of water. the pressure switch is usually located to right side of the washer under the lid you can trace a small black rubber hose down to the air bell and look for a crack and or a hole in the rubber hose.
Posted on Jan 31, 2010
CHKDSK /r fails to complete to resolve Hard Drive Error 2000-0142 / 2000-0146
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
May 01, 2013 | Dell Latitude E6500 Laptop
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
Slotomania will not open - error 404 nginx/1.0.8
A 404 error is an HTTP status code that means that the page you were trying to reach on a website couldn't be found on their server.
Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known.
No matter the reason for the 404 error, there is plenty you can do to try to get to that page you were after:
How To Fix the 404 Not Found Error
Retry the web page by clicking the refresh/reload button or trying the URL from the address bar again. The 404 Not Found error has been known to appear on occasion even if there is no real issue so a simple refresh will often load the page you were looking for.
Check for errors in the URL. Often times the 404 Not Found error appears because the URL was typed wrong or the link that was clicked on points to the wrong URL.
Move up one directory level at a time in the URL until you find something. For example, if www.w.com/a/b/c.htm gave you the 404 Not Found error, move up to www.w.com/a/b/. If you get nothing here, move up to www.w.com/a/. This should lead you toward what you're looking for or at least confirm that it's no longer available.
Jun 27, 2012 | Facebook Social Network
Error display settings
ok open your browser, top of page go to TOOLS, then INTERNET OPTIONS, then advanced. go down that screen and activate the active x controls .
Mel
Jun 07, 2010 | Microsoft Windows XP Professional
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
I think getting on and off of the internet is slower then dial up
download atf cleaner to your desktop. open and run it . www.atribune.org/ccount/click.php?id=1
Once it opens click on "select all" then "empty selected" . always run it until you get the message "no files were removed". This may take two or three runs.
I use this program EVERY time I close my broswer as it empties ALL the trash from the junk folders in windows collected from the internet, all at once. No more emptying 6 different files or waiting for a spyware detector to go through all the junk files. It just empties them, is a free programs and is very fast and efficient.
p.s. If you have a virus on the computer , it will refresh itself everytime you run atf cleaner never allowing you to get the "no files were found" message- in this case start your computer in safe mode and run your virus scanner: making sure it is up to date.
Regards.
Mar 30, 2009 | Dell Dimension 2350 PC Desktop
Have no Display
1 st set all parts currectly on its place.. properly.... now try to start u r pc.. if it doesnot work. ur windw may be cuureped man ....re instollation may solve ur problem.. best regards.. & best of luck mail-add- sigma_shiva1@yahoo.co.in
Oct 08, 2007 | ASUS CUWE-RM (CUWERMSWA) Motherboard
Washing Machines Logo
258 people viewed this question
Top Washing Machines Experts
