My Hp Compaq presario 2100 (in Bios) lists the hard drive as NONE. The laptop was working ok until it was shut down. Now it will not re-boot, and of course can not find the windows xp operating systeme. Is the motherboard the culprit, or???.
    President:
  • 1,623 Answers
It could be many things , have you checked the bios to see if primarymaster is set to auto? Maybe the hard drive is at fault? have you tried the drive in another laptop?
Posted on Jan 31, 2010
  • 12,061 Answers
Probably just the Hard Drive... try a replacement. Can you hear the drive spin up? if not then thats more conformation.
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
Laptop compaq presario 2100. i want to reformat, installing new windows, but it will stuck to ENTERING SETUP, from the beginning
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
Dec 05, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
I have a Compaq Presario Notebook 2100 when I turn-on it appears the following."disk failed and "operating system not found" what i am suppost to do. please help... Thanks a lot
You can go into the Bios by pressing F2 on startup and see if the hdd is detected there or not, you can make the bios default by pressing F9 and then F10.
If this doesnot works you will need the ricovery disc and you will have to boot to windows recovery console and there Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.This should hellp you to fix the problem.
Mar 10, 2010 | Compaq Presario 1692 Notebook
Compaq presario 2100 laptop operating system not
On my Compaq Presario Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Oct 10, 2009 | Compaq Presario 1692 Notebook
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
Bios shows not hard disk even after putting to Auto and trying User settings
This usually means Hard Drive failure, are your connections good? Is this a new drive? If you know you have a drive with os on it then boot files could be damaged. Can you boot with os disk? You can do a repair from the windows disk in recovery mode. reset bios to default values. Last resort before saying maybe the drive controllers on motherboard are bad. Take apart and do good cleaning. This worked believe it or not on a stubborn laptop that I replaced Hard Drive and still was giving me similar errors. Client says computer has been working ever since.
Char S.
May 21, 2009 | HP Compaq (319612-001) for Pavilion...
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Quickrestore- keeps shutting down mid-process
Sounds like the cd/dvd is not reading the cd's correctly, Not sure if my compaq restore cd will help but here is the link to cd 1
Download the file burn ISO to cd and boot from cd,
For giggles did you try an external cdrom?
Mar 29, 2008 | HP Compaq Presario 2100 Laptop
Compaq Presario V6000AU has problems powering up
I suspect viruses try formating the hard drive and see how it behaves - or take it to a technician to format it for you.
Dec 16, 2007 | Compaq Presario Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
