Samsung SGH-D900 Cellular Phone Logo
Posted on Feb 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Continuous redialling of most recent number
Whether I received a number (answered or not), or whether I dial a number and it is answered or not; The last number on recent contacts, received or dialled, is redialled continuously. I have to constantly check my phone (as it is on silent during work conditions) or it will start to redial. I have checked to make sure the autoredial is not checked.
Anonymous
Level 3:
  • Master 983 Answers
  • Posted on Feb 18, 2008
Anonymous
Master
Level 3:
Answers
983
Questions
8
Helped
434502
Points
2838
There may be some virus attack...
give restore factory settings ... this solves your problem....
3answers
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
2answers
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
1helpful
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
1helpful
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
1helpful
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
2helpful
Automatic redial malfunction
It's been a long time since I have used Panasonic analog phones, but the redial function in them used to be mechanical. It dialed 15 times with a 45 second pause between attempts. The key was, it expected you to pick up the handset, cancelling the redial if you got an answer.
If you got an answer and didn't do anything, it hung up and redialed again until you picked up the handset!
Could that be what your system is doing?
Carl
2answers
When I redial a number outside of my area code, how do I set up my phone to redial an automatic 1 before the number I want to dial? I have a GE cordles 28111 model
I can't redial.. How do I set up my phone to redial an automatic 1 before the number I want to dial? i have a GE digital 5-8
2helpful
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Owners Manuals are missing after the office remodel
Redial is used by pressing the redial button to access the stored numbers, each press brings up another number. To dial the number you want hit the # key. i.e. to dial a number you called 3 phone call ago you press 'redial', then 'redial', then 'redial' followed by '#'.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
