If you are connecting the HDD with different cable, then no need to set any settings to set as slave. If you are connecting the same with existing HDD cable, then need to set the jumper settings on the back side of the HDD. Instruction for making slave is on the top of the cover of the HDD.
After doing the above settings, need to check whether the HDD has been detected or not in BIOS mode.
Revert back for more assistance.
Start the hooked system and start copying the data from problem HDD to hooked system HDD, after the system boots.
sorry for the delay...
If the hooked system is having any operating system, then boot and using mycomputer you can see your old HDD & present hooked system HDD. Copy the old HDD data to present hooked system HDD.
i hooked up the hard drive to another computer set as slave. how do i start saving data?
hooked up hard drive to another computer set as slave how do i start saving data
how do i find the hooked system in what menu?
were can i find hooked system menu
