Question about Emerson ET-20F7 19" TV
My tv remote doesnt work from a distance i have to go very close to my tv for it to work, i have changed the batteries though.
    President:
  • 2,992 Answers
There are several possible reasons. The light-emitting end of the remote, or the remote sensor window on the TV, may be dirty. The light-emitting diodes in the remote may be misaligned from dropping the remote control, or they aren't putting out as much light as they should. The TV may have another light source shining on it that prevents it from picking up the remote signal until it gets very close. The remote sensor in the TV might be bad. Or there may be an interfering signal. As more people start using compact fluorescent lamps (CFLs) in their homes, they sometimes find that remote controls begin acting strangely. It's also possible the replacement batteries you put in are weak, so you might try another set.
Sorry I can't tell you which of these is most likely. I've seen them all many times. Try another set of batteries first, then try a universal remote to see if the problem is in the TV or the remote.
Good luck! Hope this helps, and thanks for using Fixya!
Posted on Jan 31, 2010
My remote control is working near the tv but at a distance its not working,itry changing batterias still not workingnot
If battery in the remote control is weak; this can happen. Repalce the batteries with new ones' and check. Still it behaves so; either the infrared sensor inside your TV; or the infrared lED, that emits infrared rays, is weak. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
There is details about how to check a remote control, using a mobile phone camera.
Nov 10, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Remote doesnt control tv
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the contacts inside the battery compartment. If rust or dust obstruct the proper contact, the remote won't work. Clean these contacts before you replace the batteries. Check this link to know about how to check the remote controls. If the infrared sensor inside the TV has damaged, the TV won't accept any remote control signals, even though the remote control is good.
Jan 16, 2013 | Sansui Televison & Video
My remote control (BN59 - 01014A) work only on short distance (1 - 1,5 m). I have a TV Samsung Led UE26C4000. I have changed batteries several times, but no results. Please help ! Thanks
Take the tv remote aparts,there is a screw in the battery compartment.I know this because i have a tv this model too.Take some Q tips soak it with some rubbing alchahols and clean the remote PCB board and wait like about 20 mins for it to dries.Put it back together again and with a new set of batteries.And take some cottons balls soak it with some rubbing alchahols and clean the tv set infer red light sensor on the tv set it self too by the tv LED power light indicaton.This solution should improve ur infer red senor reading like( 2-3 more m).
Jul 14, 2011 | Samsung Bn59-01041a Remote Control
We're having problems with our remote. It will work fine for a while, and then stop working, but when we put it up close to the box, it works again. We don't want to have to get up every time to change...
First how old are the batteries? Old batteries work off and on and often only at closer distances. You might want to try a fresh set of batteries. Also make sure the sensor on the remote and box are clean and free of oils and dust. Spray a bit of Windex on a cloth and clean them both.
Mar 18, 2011 | DISH Network IR Remote Control
The remote control doesnt work after changeing the batteries
Take out the batteries,wait like about 20 mins.put in brand new bateries,if still the same result.Remotes devices are greatly dependend on it CPU chip.The CPU chip is shorted and dead.Try website like Remotes.com to buy an original or very close to original remote.
Dec 17, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote stater problem
have you tried to change the internal battery in the remote.In my rondezvous when the battery got weak it would only work at a very close distance or not at all when dead
Dec 19, 2009 | 2004 Chevrolet Malibu
Remote won't work outside of garage it works up close
doesnt work at all or only close. if not at all, recode remote. if short distance, try reaiming antenna wire.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
TV and remote
Some suggestions: 1. Try fresh batteries in the remote. Weak batteries make it hard for the TV to see the signal from the remote. 2. Is there sunlight or ambient light hitting the TV on the infrared receiver (the part which sees the remote)? If so, it could be "blinding" the TV. 3. DO you have a ceiling fan which is casting a "flashing shadow" onto the TV? This can interfere with its ability to see the remote.
Mar 09, 2007 | Panasonic PV-DF2003 Triple Play 20 in....
Televison & Video Logo
326 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
