I am transferring files from old computer into a file. put the attache usb 2.0 in the usb port [of old computer]. Can't find attache drive symbol in the ''my computer'' section Am I looking in the wrong area or am I missing something that says USB drivers ? thanks Mike
  • Scott Hill
    Scott Hill May 11, 2010
    In order to help you we need an operating system so we can tell you what may be the issue. thanks
    President:
  • 1,623 Answers
I AM GUESSING THAT YOU ARE USING WINDOWS XP(ON THE OLD MACHINE) MAYBE YOU NEED TO RESTART THE PC TO ALLOW IT TO RECOGNISE THE EXTERNAL USB DEVICE?
Posted on Jan 31, 2010
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
How do I transfer files from old computer to new
You can't transfer programs, programs have to be reinstalled.
You can copy things like your My Documents Folder, My Pictures, My Videos, and Favorites to a usb flash drive or an external drive then put the drive into the usb port of the new computer and copy them to the appropriate folders (Documents, Pictures, Music, Videos, etc).
Apr 07, 2012 | Acer Aspire 5050 5430 Laptop
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
This is my first flash drive. How do I record to it? How do I play back from it?
Flash drives are used like floppy discs. Take off the cover, plug in the drive to a USB port and wait for the computer to acknowledge it. Usually it will get a drive letter assignment of E: unless you have multiple optical drives or a card reader that may have that drive letter in use. Transfer files by copying them in the file explorer. I like to have two windows open (one with the folder the file is starting in and the other the window for the contents of the flash drive).
Alternatively, open the file in the appropriate program and (for most OS versions) File > Save As and browse to the flash drive. Check the file name and click OK.
To use a file on any computer, open the file explorer and browse to the flash drive. Double click on the file and the associated program (or another that handles that file type) will open if it is on that computer. Then you can edit the file. If you are using a different computer, when you return to your main computer. Transfer the file back to the Documents (My Documents) or other folder in the File Explorer.
Make sure the USB port is active (try another if the flash drive doesn't work). Some USB ports can be disabled for power savings or security. On Windows the first is an Advanced Setting from the screen saver. The second is found in the device manager (Control Panel > System and Security > System for Win7).
I hope this helps.
Dec 15, 2010 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
Transfering songs to mp3
If your operating system is XP, go to start, programs, accessories, windows explorer. Go to the folder you have the music in, right click on a file you want to put on the mp3 player and see what the file type is. If the file is MP3 or wav, attach your MP3 player with the cable it came with to a usb port on your computer. It will mount as a drive (example E: F:, etc...). All you have to do is drag the file you want on the MP3 player to the mounted drive. If you have VISTA, you go to the microsoft ball in the lower left of your screen, and click one time, select all programs,accessories, windows explorer. Go to the folder you have the music in, right click on a file you want to put on the mp3 player and see what the file type is. If the file is MP3 or wav, attach your MP3 player with the cable it came with to a usb port on your computer. It will mount as a drive (example E: F:, etc...). All you have to do is drag the file you want on the MP3 player to the mounted drive.
Jan 06, 2010 | Coby MP-610 MP3 Player
Question about transferring files from computer hard drive.
Is your other drive an external or an internal drive??? If external then attach it to the USB port and see it as an additional drive in My Computer. Then you can use it as any other drive.
If an internal drive then you will have to purchase an adapter that can take this drive and get connected to the PC/laptop to through the USB port. Again visible on My Computer as additional drive and can be used such.
Dec 17, 2009 | Averatec 6100 Notebook
Trying to trainsfer program from my computer to the tevion memory
Place the flash drive (mem stick) into the USB port of the computer. Copy the files to it. Remove it from the computer and put it into the USB port of the other computer. Copy the files from the flash drive to the computer hard drive.
The memorystick (flash drive) will show up as another disk in File Manager/Windows Explorer, and disappear when the device is removed.
You cannot transfer already installed games from computer to computer, only the files. The game must be installed from the original CDs in order to function.
You can transfer documents, music, pictures, etc.
Jun 12, 2009 | Computers & Internet
Motherboard died on my Toshiba Satellite A105 S4334 and won'tboot
The esay way is to buy a USB external hard drive enclosure. Put the old drive in the device, plug it into a USB port and transfer the files. The operating system will be on your new conputer. Just copy the data files from the old hard drive.
Mar 15, 2009 | KitchenAid K45SS Classic Stand Mixer
Computer to computer
The easiest way to transfer your files is to attach your old drive to the new system as a 'Slave' drive. The system will assign a new drive letter to your old drive. Your files can be accessed and copied using Windows Explorer, not Internet Explorer. If you have a cd drive using the slave connector, connect the old drive with a new ribbon cable to the other IDE port. Set it to Master.
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
