Question about Coby TFTV2224 22 in. LCD TV
My tv has color waves going through the screen when i have av turned on. it only works with tv not av.
  • 558 Answers
This is usually a phenomenon related to high power output devices being nearby. IE computer power supply, or a backup source that needs to be replaced. It can also indicate failing components inside on the main board or on the power pack of the tv. Since you say that it only works on the tv input the video board would be my first place to look.
Posted on Jan 31, 2010
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Have a JVC AV-48WP30 rear projection tv set and the green seems to be out of place. the green image is lower than the others and is in a wave shape on top of screen and bottom.When I adjust the convergence...
Your convergence IC's are bad. If your not doing the work it will probably cost in the neighbor hood of $250.00 for a service company to do. Not a major repair.
Nov 03, 2009 | JVC AV-48WP30 48" Rear Projection...
Theres a wave going across the tv screen whenever my ps3 three is on i tried different av cables a new power cord and nothing helped
has nothing to do with your tv or ps3 or xbox ive had this problem and fixed it...you are simply running to many things in the house or on that specific circut at once and the ps3 and tv are not getting enough juice.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
I have an older big screen, and it makes this clicking sound.
Is this the actual model # AV-32F475?
If so, sounds like you have a shorted color filament within the picture tube. Could also be a video output going bad, causing intermittent shutdown when the CRT's beam current reached overload.
Aug 14, 2009 | JVC AV-32F475 32" TV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Cannot fix color without remote
Here's a link to order the original JVC remote controller for this model (AV-20220) from a major parts distributor if you need the remote to fix the colors on your unit:
JVC AV-20220 Replacement Part Remote Controller / Remocon Unit
Feb 12, 2009 | JVC AV-20220 TV
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc av-48wp74 48 in.rear
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-48WP74 48" Rear Projection...
Coby TFTV2224 22 in. LCD TV Logo
195 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
