Question about QDI Group QDI SynactiX 5EP-A (SYNACTIZ 5EP-A) Motherboard
Motherboard doesn't seem to want to access 3rd memry slot
Motherboard doesn't seem to want to access 3rd memory slot. have tried switching sticks around, no difference. Still only accesses sticks in slots 1 & 2. All 3 sticks are 256 MB PC133.
My board is: Legend SynactiX5EP
  • 67 Answers
Have you tried sticks in slots 1 and 3 with nothing in 2. If the third slot still doesn't work then its probably fried.
Sorry.
Posted on Feb 01, 2010
Asus a8jc memory slot
sounds to me that the memory your putting slot b is damaged if the amount of memory doesn't increase when you insert it. have you tried swapping them around or using another ram stick.
I too always buy matching ram, ie 2 or 4 sticks exactly the same, improves stability if nothing else...
Aug 11, 2012 | Computers & Internet
My H.p Pavilion dv2500 gives 2 short beeb sounds when i start it, but screen is not shoving anything, all leds are working, and no activity is seen on Hdd led, have tryed to change ram, but same problem, ...
Hi! Welcome to FixYA,
2 short beeps is usualy a beep code for Parity circuit failure.
Since reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other stick
If you have access to another computer that uses the same memory, try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
If it is determined the memory in the computer is bad I suggest that you replace it.
Jun 18, 2011 | Computers & Internet
My hp 5750 beeps 4 times what seems to be the problem??? thank u
This means that your memory is bad or not installed correctly. Open your pc up and remove all memory from the mother board, then dust it, place the memory back in and it should work. If you still have this problem, leave only 1 memory stick in and try starting up your pc, if your pc starts up then the other memory stick is bad and you will need to replace it, if your pc still does not start, remove the 1st memory stick and put the 2nd memory stick in its place and try booting once again. If this still does not fix it, then the memory slots might be bad, try putting the memory sticks in different memory slots and each time try booting your pc. If this does not work, try buying new ram, worst case scenario you will have to replace the motherboard. Or just replace the computer if both memory slots are bad on the motherboard, and i mean IF. Good luck!
Sep 02, 2010 | Computers & Internet
My pc's physical memry is always dump
Step 1. Power down your machine, hit the master power supply switch
Step 2. remove your Memory stick(s) and blow out your RAM slots
Step 3. Try one stick at a time, booting up to see if you get the error until you can figure out which stick (if any) is bad.
Step 4. try the same procedure with the second slot (if applicable)
You may have a bad stick of RAM, but not bad enough to be recognized by POST
Apr 19, 2010 | Computers & Internet
I can't get my Acer aspire e380 to accept another
How many slots for RAM in the motherboard?
If there are 4 slots, are the slots equally-spaced, or are they located as two pairs of slots, with a gap between the 3rd and 4th slot?
Some computers _REQUIRE_ RAM only in the 1st and 3rd slots, or only in the 2nd and 4th slots.
Some computers "beep" when 3 out of the 4 RAM slots are populated.
Some computers require the size of the RAM in the 1st slot to match the size of the RAM in the 3rd slot,
and the size of the RAM in the 2nd slot to match the size of the RAM in the 4th slot.
Does your computer "beep" when one stick is in the first slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the second slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the third slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the fourth slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the first slot and a matching stick is in the third slot, and the other slots are empty? How much RAM on those sticks?
Jan 23, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Asus A7N8X-X (third memory slot)
Sounds like either a bad stick of memory or a bad dimm slot . Have you tried the memory on another motherboard ?
Jul 18, 2008 | ASUS A7V8X Motherboard
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
QDI Group QDI SynactiX 5EP-A (SYNACTIZ 5EP-A) Motherboard Logo
77 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
