Question about Refrigerators
Freezer shelves we need freezer shelf , how can we get one MODEL ET8BPKXKQ00
  • 1,531 Answers
I am going to asume the shelf you need is to hold ice trays.that is the only shelf showin the parts break down for this model. the part number is 2262654 or it may convert over to this number w10142524.and they can cost about twenty dollars you should be able to go to your local parts store and buy one is not at least have them order it. i hope this helps with what you are looking for.please let me know how things turn out for you
Posted on Jan 31, 2010
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Can i remove the shelves in frigadaire frezzer model frs6r4eq4
Good Afternoon Friend,
I understand you want to know if you can remove the freezer shelves in your Frigidaire refrigerator, model# FRS6R4EQ4. All the shelving in your freezer is fixed, however the bottom shelf, which is located on top of the freezer basket, should flip up to allow more room for tall items that you wish to store in the freezer basket. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
I need a door shelf for my Frigidaire side by side refrigerator (# FRS6R5ESBFPN # 241691311)
  • You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
  1. Upper freezer shelf - http://www.appliancepartspros.com/Appliance-Parts/frigidaire-bin---door-frzr---upper-item-number-ap2115843.aspx
  2. This one is a replacement for the lower 3 freezer shelves http://www.appliancepartspros.com/Appliance-Parts/frigidaire-freezer-door-shelf-item-number-ap2115974.aspx
  3. This one is a replacement for the 2 bottom shelves of you refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2115741.aspx
  4. This part here is for the 2 upper shelves of your refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2116036.aspx
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Frigidaire FRS3R5EMB Side by Side...
GSS25LGMCC Side-by-Side. On left freezer side, foam filled walls have contracted and top two wire shelves can no longer rest of molded side supports and fall. Need shelves about 1/2" wider
never heard of that happening,are you sure you're not missing a support that the shelf slides on or you have the wrong shelf for that spot.i'm sure you tried the shelves in all the slots,if the wall did push out like you say the only thing i can suggest is to buy another support and get longer screws and put the screw through both supports and hang them like a single support to make up the difference.next what caused this to happen,is the freezer staying cold?if you give a parts store your model number they will sell you the same shelves that you have.
Apr 30, 2011 | GE GSS25LGM Side by Side Refrigerator
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
BROKEN SHELF CLIP IN FREEZER
Try to find as many numbers or letters after the ED25PW for example model ED25PWXAN01 There are about 30 versions of that refrigerator so start by entering the basic ED25PW into the model and search feature. And go to a link of your choice and click on the photo refrigeration shelves. There you can choose the parts from the display of the parts and components of shelves.
You can visit my link below. Let me know if I can help you further, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Jun 18, 2009 | Refrigerators
Upright freezer.Two shelves freeze up. One doesn't. Why and is this a problem
look to see if the shelves are in fact not shelves but evaporator coils . if the shelf is connected to small tubing, then that tubing flows freon that freezes the shelf. if its clearly not connect to any tubing or piping then its just a shelf and gets residual cold from evaporator shelves. if it is connected to tubing like the others and not getting cold then you have whats called a restriction. . particles have plugged the tubing and no freon is feeding the shelf. if that is happening then consider having a pro recover the gas , unplug the tubing , replace the drier and recharge it. if its an older unit and you are getting by then maybe not worth the expense.
Nov 01, 2008 | Kenmore Freezers
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
