Question about Solid Audio Car Audio & Video
I installed a two and four chan amp in my gmc safari mini van battery guage on dash goes real low and van almost turns off my bat is brand new one day old should i use a second bat to supply pwr to amps without hurting van current output voltage
  • 86 Answers
You can go one of two ways. You can buy a high output alternator or run a extra dry cycle battery and you should run at least one or two capacitor here is a link for info: http://www.bestbuy.com/site/Rockford+Fosgate+-+1-Farad+Capacitor/8286482.p?id=1172880157454&skuId=8286482&st=capacitor
Posted on Jan 31, 2010
1998 Gmc safari astro van just got a new starter about two weeks ago i had to use starting fluid to start it . Well four days ago went out to start it wouldnt start tried starting fkuid started rifht up ....
maf/vaf sensor
crank /cam position sensor
low compression
faulty battery
the list of possible faults goes on
have the fault codes read first to narrow don the list
Sep 02, 2017 | Cars & Trucks
Im not getting fuel in the carb. fuel pump is new and filter is good any suggestions?1999 safari van
ok make sure there is gas in the tank DO NOT GO BY THE GUAGE
dip a stick in the tank if possiable or tap on the tank from underneath
if it sounds hollow it\'s empty I\'ve seen many that just needed gas
Check the like from the tank to the pump ther will be rubber connectors at each end if one is cracked it will suck air and no gas another check would be to take the line to the carb off the pump turn the motor over and see if you have fuel to the pump
if not then check the line to the tank
Mar 01, 2014 | GMC Safari 1999-2004 Mini Van RH Convex...
1999 gmc safari van won't turn over no clicking or anything new battery still nothing what do you think?
Is the anti-theft / security light on ?
Will it crank in neutral ? Do the warning lights come on the dash when you turn the key on ?
Feb 24, 2014 | 1999 GMC Safari
I have a 2000 GMC safari van 2-wheel drive. When it shifts to 3rd it seems to jump into neutral. What can cause this? Changed transmissions and it is doing the same thing
My local transmission specialst tells me that ALL GM van transmissions run hot. Especially within the Safari/Astro design - that doesn't reflect the wind very well (compared to today's smaller mini-vans). He recommends ATF aux cooler (LPD Design) be installed in all Safari / Astro vans - even non-towing vans. For example, Hayden 678 or 679 LPD design.
re: http://www.summitracing.com/parts/HDA-678/
If wondering, I installed Hayden 679 in my prev AWD Safari van and installed Hayden 678 in my wife's smaller size GM mini-VAN. re: http://i178.photobucket.com/albums/w251/Spike99-Pictures/Montana%20Van/AuxTransC- ooler-UpperSupport-2.jpg &http://i178.photobucket.com/albums/w251/Spike99-Pictures/Montana%20Van/AuxTransC- ooler-LowerSupport-1.jpg
As a suggestion, install the LPD aux cooler design (re: Tru-cool or Hayden 678 or 679) in your "running hot" GM van. These ATF coolers work great in my GM vans...
Sep 13, 2012 | Cars & Trucks
My 1992 gmc safari van will not turn over
check the neutral safety switch move the shifter around it neutral
May 28, 2012 | 1992 GMC Safari
95 gmc safari problems
yes delivers the fuel bat is not enaf pressure replase fue pomp end you be ruaning agein
Jul 12, 2009 | 1995 GMC Safari
1994 gmc mini van turn signal broken need help on how to replace
If the switch is broken, you need to remove: driver side knee bolster, snack tray/drink holder and dash rim. Remove the lower steering column cover (2 screws).You will need a E5 torx socket to loosen the upper cover. Alldata recommends removing the lock cylinder to access the 2 torx screws holding the switch in place, but I did it without (disabled the air bags and removed the driver side, accessing one screw through the steering wheel, top screw with bit and ratchet wrench). The wiring harness connectors attach to the main block under the steering wheel. Auto Zone has a replacement switch assembly for about $180, dealer price $417. E-mail me if you need further instructions...
Apr 18, 2009 | 1994 GMC Safari
Car Audio & Video Logo
Top Solid Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Solid Audio Car Audio and Video Expert? Answer questions, earn points and help others
