Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Lines on copy's when using auto document feeder on epson artisan 800
You don't say exactly, but I'm guessing that scanning when laying the document flat on the glass (ie, not using the document feeder) you get a printout that is fine. It's only when you use the document feeder that you get the vertical lines on the printout?
Epson repair tech in my area says this is a common problem. It is due to the aging of the calibration strip (the white strip at the underside of the flat bed glass near the "home" position). It shrinks after years and can't provide correct calibration.
This is a problem only with the pages fed through the document scanner. It sounded weird to me, but the tech said he stocks lots of replacement glass and does lots of these repairs to Epson scanners.
It might be cheaper to buy a new scanner rather than get yours fixed. He said it's pretty inexpensive to do this repair, but scanners are also pretty cheap.
Good luck.
Posted on Feb 03, 2010
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
Epson artisan 810 prints vertical black lines on all documents
this problem is usually fixed easily. this commonly occurs when print head is clogged. I use a facial tissue and alcohol to clean the head with the ink cartridge in an upside down position (if possible) then i print one or two test prints to get it back to normal.
Jul 06, 2014 | Epson Artisan 800 All-In-One InkJet...
THE ADF ON MY EPSON 2540 PRINTER WILL NOT ALLOW ME TO USE THE FEEDER
LIFT THE LID WHERE THE DOCUMENTS ARE FED IN AND CLEAN THE RUBBER ROLLERS WITH DAMP CLOTH AND CHECK THEY ARE NOT WORN YOU MAY NEED TO REPLACE THEM.
May 19, 2014 | Epson Artisan 800 All-In-One InkJet...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
My Epson Artisan 800 prints only 1 inch of anything and then spits the paper out
Try the following to resolve this issue.
1. Check if same issue appears when using your Artisan 800 as a standalone copy machine.
2. Try printing from a different application to isolate the issue further. You can also print a windows test page to check if this issue is caused by the application that you are printing from or by the printer driver.
3. Reinstall Printer Driver.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
When using the copier a 1/2 inch black line on right side on top of the copy. Cleaned glass, no nicks just started. it does it with autu and manual feed.
Did yo clean the thin glass on the extreme left side. If you lift the document feeder cover, you'll see the thin glass strip. Make sure it's clean.
Mar 05, 2011 | Epson Artisan 800 All-In-One InkJet...
Black lines in pictures printed from Artisan 800
I have the same issue, It seems 1 line of pixels is overlapping with the next set of pixels and makes a dark line horizontally.
Apr 23, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 800 will not print
please make show that ur connection to the printer is correct.mostly if u using usb cable.uninstall and reinstall ur printer drivers can solve the problem.
Apr 19, 2010 | Epson Artisan 800 All-In-One InkJet...
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
201 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
