Question about Sony Ericsson Walkman W980i Cellular Phone
I the problem was when i turned my phone off all was working great then when i switched it on again the key board light up and thats all it does no screen at all. then i tried to switch off again which it wont do just the key board stay light and thats it help how can i fix it?
Hmmm... I have the same problem... did you end up getting a solution for this?
Posted on Apr 15, 2010
Se W980i problem
Sounds like your phone requires a master reboot, however if this fails then it sounds like a software malfunction and you would be better of then to get a new phone as the cost of repairs outway the cost of buying a new one.
Feb 12, 2010 | Sony Ericsson Walkman W980i Cellular Phone
Sony erricson w980 wont turn on
this seems like a common problem with this phone, as I had the same trouble with mine. I took it in to get fixed and it then worked for a while, but now it is playing up again and keeps turning itself off. Not happy!!!
Jan 06, 2010 | Sony Ericsson Walkman W980i Cellular Phone
1985 190e Engine turns over, won't start
when the car ignition is turn on all accessory lights should lite up telling the computer everything is in good contact. If none of the dash lights is not lighting up you don't have a good ignition contact and computer is not getting any power. your stater will crank and turn the engine over only but the fuel pump and ignition module and other accessary is not turn on, the car will not start. What turn everything on is your computer, computer; control all items like fuel pump, sparks etc. You have to get all dash light working again in order for computer to turn on. Check all the fuses and relay under the hood, next your ignition switch in your steering wheel may be faulty allowing only starter to work and not others. this unit wear out and common problems to all cars, parts is 35 buck to replace and you going to have to take the steering columns apart to get to it. Not easy but it will take time. Get all the dash light working and you will be back in the game. good luck and hope that help some
Aug 06, 2009 | 1985 Mercedes-Benz 190
Harris TS22 keypad problem
Try and Get the Unit tore down to where you can look at the bottom of the keypad. you may have water or something between the board and keypad. I recommend cleaning with isopropal alcohol and q tips. See if that gets you any where
Jul 09, 2009 | Fluke Networks TS22A Test Set With Speaker...
Power will not stay on
HI, make sure there isn't a short in the actual outlet wall socket. if the outlet wall socket is in good condition, this will confirm power board failuer.
You will need to replace the power supply board in this unit in this case.
Jun 13, 2009 | Reebok Vista Treadmill - RBTL13305
Noka N95 8gb keeps turning off and not restarting
ba83ee5.jpghello,you do not try master reset *#7780# or *#7370#
please remove your mm c card and switch off your mobile and 5 minute after you try without you mm c card; then no solution so, you are watch nokia care
Apr 20, 2009 | Nokia N95 Cellular Phone
Phone always switching itself off
Well, you can try this; Check the behavior of the phone with a new battery and see. A battery problem could cause this. If this does not work, then you would have to check if no key on the phone is stuck. But the second is not likely since a stuck key would cause a phone to freeze.
If this does not solve it, then you would have to see a nearest mobile phone technician since it will be an internal problem on the main board which will require the hands of an experienced person.
Thanks
Nov 30, 2008 | Sony Ericsson W910i Cellular Phone
Keyless entry keylob want lock or unlock doors or trunk.change battery and checked all fuses.
You need to program the remote. Get in to the car and LOCK all doors with the switch on drivers side door. Take the key and insert it into the ignition cylinder in and out 6-10 times, until the flashers/hazards flash on your dash board. Or just keep putting the key in and out (nice and easy now, not fast) until you see the lights on dash flash. After the lights flash, turn the key into ACC mode to make the whole dash light up.(do not start car) .With the key in ACC position, hit any button on remote, that will make the hazards flash again. Turn key off and unlock door with switch again. Open door.DONE.
Good luck.
Jul 15, 2008 | 2001 Nissan Altima
RCA 32V432T television ,Turns on and off on its own and runs through channels continuously
The problem is most DEFFINATELY the control board behind the user buttons.
You have 3 options to fix this...
1. Replace the new board completely (no garuntee your getting a "new" part).
2. Replace the tack switches (requires soldering and patients [alot of them]).
3. Remove the board and snip the one wire marked "Key". I didn't snip it so much as correctly pulled the wire out of the plug itself. By removing that one wire from the board you disable just the buttons. You still have complete use of the remote. Who the heck walks over to the TV these days anyway!?!?
Dec 04, 2007 | RCA 32V420T 32" TV
Sony Ericsson Walkman W980i Cellular Phone Logo
167 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
