Question about Refrigerators
Refrigerator won't run
I drilled a small hole in a refrigeration line by accident while trying to attach a latch to my door. can i patch the hole and recharge the freon?
  • 41 Answers
U will need to do a vaccum , atleast b4 u recharge as moisture gets in , iwud replace filter dryer , not an easy job
Posted on Jan 31, 2010
How can i attach a lock on my refrigerator
Here is an easy way. Buy a lock hasp from a local hardware store. Mount it to the right or left side, depending on which way it opens by holding it up so that the entire lock hasp covers the opening of the door seal width, but allows you enough room to drill the holes into your refrigerator sheet metal. If too small then buy a larger or if to big buy a smaller hasp. Use common sense and your best judgment. Once you have found one the correct size, you will need to mark the position of the holes that you will have to drill through the sheet metal. Once the holes are marked they will have to be drilled. You are going to permanently mount this hasp to the refrigerator with a pop rivet gun, so ensure you want to do this before you drill any holes. You will also want to buy a hasp that has holes no larger than 1/4" to make it a solid mount. Once you buy the pop rivets that fit through the holes in the hasp and are long enough to grab the sheet metal of the refrigerator, use the recommended drill bit size for the rivet. That info is on the rivet box. Once all holes are lined up and the door and hasp will allow you to put a small padlock on it use a pop rivet gun to permanently install the hasp to the side of your refrigerator. After it is installed, simply close the door and put your padlock on it and snap it shut to lock it. I learned how to do this, because sadly I lived with someone that had an eating disorder and the food had to be locked up. I pray you aren't going through the same thing, but this works!
Feb 11, 2012 | GE Refrigerators
How to fix a door latch of Samsung SMH9207ST microwave?
The small tab on the latch broke so the spring was loose. Took my drill and drilled a small hole in the main body, ran a small wire tie thru it and hooked the spring to the wire tie. Works great and more durable than the orginal dinky hook.
Dec 10, 2011 | Microwave Ovens
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Beer tap
Good day,
If it has the condensor coil mounted on the back of the machine.
(black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door.
This applies to both sides. Hit one of those and your finished.
Jul 21, 2010 | Frigidaire FRT17G4B Top Freezer...
How to fix a crack in an interior refrigerator liner?
whirlpool has a repair patch kit drill a small hole at each end of the crack to keep it hrom speading
Jul 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
I'm using a kenmore refrigerator as a kegerator and I need to know if there is anything I should be aware of on the side of the fridge walls as I have to drill a hole into it to attach the hose from the...
Any lines that run through the cabinet should go up the back or and/or around the door. I would carefully cut a hole in the liner and pull the insulation out in small peices just to make sure.
Apr 24, 2008 | Refrigerators
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in refrigerator door coming out slow
Hi Ben22 Sounds like some thing pluging the water line or the water line pinched some where.. if the hole was 1/4 inch you should get enough water with that big of a hole. I would check the water line for a obstruction. Let me know if this helps. Krazytech
Sep 29, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
