Question about Ovens
F 2 and F3 appear when using oven
  • 1,531 Answers
These usually indicate a defective sensor,electronic oven control or the wiring in between. you need to check the resistence of the oven probe if it is not correct the change it if the resistanc ei s good then change the electronic control if the resistance is less than 800 ohms and more than 3000 ohms it is bad
Posted on Jan 31, 2010
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 13, 2011 | Maytag Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
JCSP28GP1BG - GE oven F3 code appears and beeping starts when: 1. Oven is turned off completely as well as 2. After turning temperature up to any amount, F3 code appears and oven temperature does...
The F3 error code is mostly due to fault with the oven tempreture sensor in usually all units. You can perform a ohms test on the sensor at room tempreture with the unit having no power going to it would read between 1000-1100 ohms. any less then this would constitute you replacing the sensor in the unit. Part number I have on that part from sears is WB21X5301 and looks like this click this link http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Range-Parts/WB21X5301/0022/364/Model-JCSP28GP1/0432/0124111?keySuffixId=NA&productTypeId=0124111&searchModelNumber=JCSP28GP1&subCompDesc=Main%20body&brandDesc=GE&modelDesc=GE-FREE-STANDING-/-DROP-&blt=11 appliance parts pros sometimes sell after market parts or not original it would still work the same but you would have to connect it useing your own connectors and have to splice it in. If you havent ordered that part for your unit yet I would order using the number I provided along with from this company they are much cheaper http://www.allbrandonline.com/Default.aspx?Page=My%20Account%20Profile If you have any further questions message me back Thanks Rick
Jul 10, 2011 | Ovens
Hi, F3 mag curr. what is means and how do I fix it?
F3 is an complex code.
Easy fix is look at the transformers and the capacitors and the diodes.If it seems that any component has changed its appearence then fix it and replace the F3 fuse(3rd one from the front).
If the magnetron is bad ,then to check that you must know how to use clamp ammeter.
let me know if you know how to use clamp meter .
I will give you the solution .
NOTE oven has 5000V in it.
make sure you dischared the capacitors.
Thanks
please rate my work
Apr 16, 2011 | TurboChef TORNADO Electric Oven
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
When lighting oven f3 appears
on our maytag a F3 means a shorted or open oven temperature sensor. you can google your oven model # for its codes
Jun 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 | Ovens
F3 Fault Code appears
What it needs is a new temperature sensor.
Unplug the range. Open the oven. Look in the top right or left side of the oven for a metal rod about 1/2 the size of a pencil. Remove the screws holding it in. Pull it out very carefully. Unplug the wire connector. Reverse this order to replace the temperature sensor.
Sep 15, 2009 | Maytag 30" Built-In Double Electric Wall...
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
