Question about Maytag Neptune FAV6800AW Top Load Washer
I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.
  • peggy_wolfe Jan 31, 2010
    FAV6800AWW
    serial # 10659686
I too heard "loose marbles" sound when the washer was beginning the spin cycle. Take off the back panel and you will see two pumps on the bottom of the drum. As you face the machine from behind, the pump on the left is a drain pump. There is a rubber hose that leads to your drain. I had two pennies inside the drain housing. I removed the rubber hose and the pennies. Noise gone. Now to figure out how they got there????
Posted on Oct 28, 2013
  • 526 Answers
Peggy,
“”I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.””
With the washer not working do you have an error code to the LED display? Can expand on the washer not working?
Do you here the grinding noise in wash/agitate cycle when the tumblers are turning?
If so you need to remove the tumblers and see if there are any coins under the tumblers. See page 37 of the Service Manual.
The SM doesn’t call out the torx driver size required for tumbler removal it’s a #20 torx driver.
You can enter into Service Mode and empty the wash water with this process.
To pump out the excess tub water;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Rich
Posted on Jan 31, 2010
I have bobcat s300 600 hours it has noise in front left side when machine moves can anybody help me
Since you didn't specify, I'm taking a guess it's making noise only when you're driving it, not when sitting an operating the bucket or aux. hydraulics. You have to describe the noise, is it a whine, groan, high or low pitched, grinding, crushing marbles, what? Describe the sound.
Feb 16, 2015 | Ertl Big Farm Bobcat Skid Steer S300 With...
When our washer goes to spin cycle, sometimes it makes a noise like there are marbles or bb's in it. My wife has heard it. We did two loads tonight and I listened, but of course, it did not do it tonight....
Sounds like bad bearing. In most units, it's a "simple" replacement. If you have a Bosch, they often want a whole unit including the tub. Cheaper to replace.
Nov 02, 2013 | Washing Machines
Maytag washer model MAV6200AWW
pop off the front panel and look at the inside of it,if you see black dots on the bottom half and on the other walls like half way up from the bottom you have bad tub seals,the seal is made of metal and rubber,when it leaks and in spin it will shot out water and it will be black from the rubber,also you can fill it as high as it will go,then turn the timer to spin and watch where the tranny.and tub meet,if it sounds like marbles spinning and grinding and water leaks out it's the seals.if so time for new washer
Jun 23, 2013 | Washing Machines
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Grinding noise on rt. turn from front end
If it sounds like marbles crushing together then its your CV joint/s are bad if your getting a metal grinding noise and will not stop then its a bearing bad
Jan 21, 2010 | 2007 Chevrolet Monte Carlo
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Noise in wash cycle
This is normal, because your washer will make sounds that you may not have heard from other washer.
Jun 07, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Maytag Neptune FAV6800AW Top Load Washer Logo
357 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
