Question about Samsung Refrigerators
My samsung fridge side walls gets very hot to touch what is the reasons? why it is heated?
  • 1,531 Answers
The coolant lines run throught cabinet of the fridge.there will be some heat felt on the outside of the fridge and the center divider, if the temp is real warm to the touch then you might have a condensor fan thatis not operating causing excess heat.
Posted on Jan 31, 2010
We have a Samsung Silver Nano Health System Fridge/Freezer. The outer skin is very warm. Is this normal.??
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Dec 26, 2016 | Samsung Refrigerators
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
My Samsung RS2530BBP is hot around the freezer door and the freezer is not cold enough. What could be the problem?
Sep 05, 2015 | Samsung Refrigerators
Door rubbers heating up to much
Dec 25, 2014 | Samsung Refrigerators
Center dividing wall between two sides on our Whirlpool fridge is hot to the touch. What can be causing this?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 07, 2011 | Refrigerators
Inner walls over heating, fridge side stoped working
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
Mar 06, 2011 | Samsung RS2630SH Side by Side Refrigerator
My roper side by side is getting hot
Depending on where your fridge is getting hot, this could be a normal operation of your fridge. if your feeling heat on the outside or in between the freezer and fridge this is normal due to the heating element inside the walls of your fridge. this heater is ther to eliminate any condensation that may occur inside the walls and insulation of the fridge. if you are getting a large amount of heat coming from the back of the fridge this could indicate that the compressor may be on the way out, and constantly running.hope this helps.
Thanks
Oct 12, 2009 | Roper Refrigerators
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
1,323 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
