Question about Cell Phones
Hi I have a small crack on the outside of
Hi I have a small crack on the outside of my sharp sh9023h phone and also a tiny chip in the chrome edging. Can these be fixed? I'm more concerned by the latter issue.
Thanks
Kitchen sink has tiny cracks. Why are cracks appear and how to fix this sink
Hi there it might be that you have used a harsh abrasive chemical to clean the sink and there's a residue remaining from it eating into the surface causing theses cracks to. Appear
Or the chrome enamel surface. Is breaking down try using a 're chroming agent like silvo
Jul 03, 2016 | Dishwashers
My news feed is tiny and centered to the screen how can i fix ive tryed reinsulting facebook but it just go right back to being tiny
Facebook Customer Support:
Phone Number: 1-650-543-4800
Average Wait: 12 minutes - 24 hours, 7 days
http://gethuman.com/phone-number/Facebook/
Facebook Customer Phone Number Shortest Wait Best Support
IF YOU LIVE OUTSIDE THE USA CLICK ON LINK ABOVE AND THEN CLICK
ON CALL FREE VIA WEB.
Suggest trying a new browser like Firefox or Google Chrome
YOU CAN GET THEM INSTALLED AT THE LINK BELOW:
http://www.ninite.com
By the way their are over 27,000 unanswered Facebook questions
that need to be answered. If no one answers them I will attempt
to.
You also might try Ctrl + and Ctrol - for resizing screen in a browser.
to.
Apr 17, 2015 | Facebook Computers & Internet
An enamel cookware baking dish that I particulary like fell and cracked on the outside (red surface) and there is also a small chip in the inner area where the food is cooked. Is there anything I can do to...
the crack may get bigger with use and any repair would have to be with foor safe materials / you could only use it with a coking bag ( makes cleaning easy . but its probably time to replace it , mm
Jan 10, 2010 | Crock Pots & Slow Cookers
My BB Pearl 8100 tracj ball will not select when I
The trackball dome and/or module is bad. Try www.bbmedic.com
Dec 12, 2009 | RIM BlackBerry Pearl 8100
Small tear drop leak from chrome bathroom radiator, where the joint is, poor weld!
I turned off the radiator and let the leak stop, located the pin head hole, cleaned the tiny area with emery paper, put a spot of flux in the hole then applied a tiny drop of solder. Worked a treat.
Nov 08, 2009 | Google Chrome
How do you put the merory chip in to the
hi, i have tha viewty, and to put the memory chip in, you have to take the battery out, and there is a tiny slot going into the body of the phone, it might be the same for your phone x
Oct 09, 2009 | LG KU990 Viewty
How to Fix Cracked LCD Screen?
Dear Confused,
Sorry to hear about your phone screen.
There is only one way to make your screen look better, but it will not "fix" the crack. I have done this and sometimes i cannot even tell my screen is still cracked and i didnt have to pay Apple $350 for a new piece of glass.
Here is what you can try:
1. Go to a auto parts store and buy a "Winshield repair kit" for small rock chips that look like a bullseye style chip.
2. CAREFULLY CLEAN THE GLASS WITH ALCOHOL and let dry for 10 minutes. Then heat up the glass of your phone with a hair drier for about 2 minutes so its hot, but not too hot to handle.
3. Then very, very slowly and cautiously, cut the tip of the nipple on the "epoxy/resin" bottle they have in the repair pack and while the phone glass is still hot (you may want to cut the tip of the bottle first, then heat up your phone), gentle squeeze the clear resin into and along the crack in your phones glass....Squeeze the resin directly along the entire length of the crack while attempting to squeeze it INTO THE CRACK...its diffucult, however, the heated glass will **** in the cool resin and actually fill in the crack.
Make sure not to get the resin on the phone or your skin!!!
AND BE PATIENT WHEN applying it.
ALSO, try to do this on a sunny day, because you have to place the glass in direct sunlight, or under a UV light to allow the epoxy/resin to cure. IT WILL NOT WORK UNDER A NORMAL LIGHT BULB. SUNLIGHT Actually works best.
Leave it in the sunlight for at least 1 hour or longer. Then wait another 24hrs before taking a razor blade to scrap off the excess resin that has built up on the glass.
FYI, it the crack to too deep the epoxy will seep thru the glass and this process wont work.
However, if your lucky this should be what your looking for!
Good luck and let me know how it goes!
THanks,
Mark
Jan 02, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Cracked camera lens on my Motorola Razr
you just need to replace the housing of the phone to correct this issue.
Oct 24, 2008 | Motorola Mobility RAZR V3
Prob
On the top where the latch closes on the chip take it and put a curve in it to where it bows up. Mine did the same thing after i did that it worked fine.
Jun 28, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
