Question about IOGear GCS632U 2-port KVM Switch
My IOGear 2 port KVM switch USED to switch between my two computers when the "scroll lock" was tapped twice. Now it doesn't work. What do I do to fix this. The key board & mouse both work when directly hooked up. Thanks!
I had the keyboard and mouse USB's in the wrong ports on the KVM switch. Mouse works in both, but keyboard only in one. Maybe??
Posted on Jun 01, 2010
  • bradfdx Jul 23, 2011
    It seems odd but this is it. Only one of the USB ports will accept toggle commands from the keyboard. On mine, it's the right-hand one. If the keyboard is plugged into the left-hand one, I can still type but can't address the KVM with commands to toggle, etc.
Related to Robinson's solution, if you're using a Logitech wireless kbd/mouse only one of the ports will allow switching.
Posted on Oct 21, 2010
  • 12,061 Answers
Perhaps you must assign those keys in setup?
Posted on Jan 31, 2010
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
AN IT person set up my computer so that I could switch back and forth between the old and new computer (Win 7). I click "Menu", Click the > arrow 6 times to select the appropriate bos, I then select...
On that model of KVM switch,making sure Both computers are on, you should only have to hit the "Scroll Lock" key twice, then hit the up arrow to switch between computers. like "tap-tap" on Scroll Lock key then "tap" on the up arrow key. See if that works.
May 14, 2010 | IOGear MiniView GCS62 2-port KVM Switch
How to daisy chain iogear 8-port miniview
GCS78 can be daisy chained up to 3 levels only.
Let's say you will start with two levels. KVM1 and KVM2.
The ports 1 to 7 of KVM1 should be available for computers, but the port 8 of your GCS78 is for your KVM2.
The port 1 of your KVM2 should be connected to the port 8 of your KVM1. And the rest of the ports of KVM2 should be avail for the computers as well.
Toggling between computers. You need to quickly hit Scroll Lock twice to enable the OSD of your KVM switch. From there, it will give you an option to select which computer you would like to access.
Or you may manually toggle between computer. Here's how:
Scroll Lock twice + port # - Example: Scroll Lock twice + 5 + Enter - The KVM will switch to the computer that is connected to port 5 of KVM1.
If you would like to switch to the computer that is connected to KVM2:
Scroll Lock 2x + 8 (because KVM2 is connected to port 8) + Enter - now the focus of the toggling is in KVM 2. Now, you may hit again Scroll Lock2x + port # + Enter.
You may also refer to the user manual of your KVM for more info. Look for the OSD portion.
Oct 29, 2009 | IOGear (GCS78) 8-port KVM Switch
Not switching systems
Make sure your keyboard is plugged into the keyboard port of the KVM. The IOGear KVMs use a keyboard and mouse emulation. Due to this the keyboard port is the only port will recognize the Scroll Lock command.
Oct 12, 2009 | IOGear Computers & Internet
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
IOGEAR KVM SWITCH WILL NOT TOGGLE BETWEEN COMPUTERS
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Howto switch between computers with iogear gcs612a
A probably solution is to press the "Scroll Lock" button (usually at the top-right of the keyboard) twice in quick succession. Give it a try!
Mar 30, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
IOGear GCS62 2-port switching problem
I have a similar IOGear KVM switch. I use the Scroll Lock button twice to switch between PCs.
Hit the Scroll Lock button twice see if that does it for you.
Feb 09, 2008 | IOGear MiniView GCS62 2-port KVM Switch
Key combination
Quickly press Scroll Lock twice and you should be able to toggle.
Apr 05, 2007 | IOGear MiniView GCS612A 2-port KVM Switch
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
1,396 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
